urgent help before i start building T48 sub and Dr250 Top
Deejblackboy
#1 Post by Deejblackboy »
hey guys
i am having some lil issue finding these Baltic birch and PL Premier Glu on my island at every hardware store in my island and i was wondering if anyone of these can work to build these box T48 in DR250
Wood is:
plywood cedar 12mm ab 4x8in
plywood beach 12mm b/bb 4x8in
plywood formply 12mm 4x8in
plywood Marine 12mm... 4x8in (Not cheap lol)
regular exterior plywood 12mm 4x8in
Glue is:
_ Titebond III Ultimate Wood Glue with silicone to finish..... http://www.titebond.com/product.aspx?id ... 3970f736af
_ Titebond II Premium Wood Glue with silicone to finish.....http://www.titebond.com/product.aspx?id ... 7a38930fa2
Video of both glue just in case.......https://www.youtube.com/watch?v=VDxDahRQIgA
the box i need to bill is the T48 and Dr 250
so i was wondering also how much sheet per box i need to buy
_ T48 ..15inch 24x48 per box is =
_ DR250 per box is =
last question about the top DR250
i actually going to use 3 amplifier hi - mid - bass for my system......i usually does use Mid bass driver on most cab for 2-way system
and for some reason am a lil curious in confuse about these drivers that goes in these DR250 box...so i was wondering which will be best loud in better choice for Live music band, dj , and other application with just top...so which one will be best n loud for my system
_ 3010MB....http://www.parts-express.com/eminence-k ... r--290-667
- 3010HO...http://www.parts-express.com/eminence-k ... r--290-664
these driver i going to order from speakerhardware.com...the best dealer in great person
Dr250...any idea what brace or bracket i can use to stack these box together with metal or build out a wood or even purchase online
sorry for asking all these question even do i have the plans with all these information but i just want try my best building the correct in best way not forgetting loud as possible........thx again guys
ctmullins
Re: urgent help before i start building T48 sub and Dr250 Top
#2 Post by ctmullins »
Titebond won't work unless all of your cuts are perfect. PL Premium is recommended because it expands as it cures, filling any gaps between panels. Titebond does not expand as it cures.
This info should be on the first page of your plans.
-todd
2 x W8 panel-mount
2 x T39 24" 3012LF
#3 Post by Bill Fitzmaurice »
Deejblackboy wrote: Dr250...any idea what brace or bracket i can use to stack these box together
Those in the plans and the Sketchup.
Glue is:
Do not use traditional woodworking glue.
DR250 plans, page 2.
Also the one in the plans. :wall:
#4 Post by Grant Bunter »
It seems loctite prohibit export to Saint Martin.
So you need to find an expanding polyurethane adhesive. Some people have tried Selleys brand, Sika brand and others. So, don't be in a rush, take your time, you will find something suitable.
You might also find someone willing to ship you a box or two of PL Premium from the USA.
As long as that product has 5 plies of equal thickness, you're good to go with it.
It would be handy to know what it's made from.
The Deltalite 2510 is most commonly used. These cabs will exhibit distortion before they actually reach their voltage limit, which means you either need to 1. Turn down, or 2. Build more cabs...
