z-audio wrote:When using Behringer Ultradrive , which one is preferred 24db or 48db slope and why?
It depends on
where you want to apply the slopes.
If the application is, for example, high passing your subs, in the past, Bill has said something like: "use as steep a slope as possible".
If you have a DBX driverack, IIRC the steepest slope is 24dB.
So the minimum acceptable slope is 24dB.
Since your question relates to the DCX2496 however, as a high pass for subs, you should use a 48dB slope.
Two reasons:
1. Because you can.
2. It affords the maximum amount of protection for your driver(s).
You
could apply the same thinking to low passing tops/mains.
After that, you enter the grey area, that as Radian has suggested, requires experimentation.
That relates to the crossover region.
You could use 24 or 48dB at a set frequency, eg 90Hz low pass on subs output and 90Hz high pass on tops/mains output.
What that does in terms of affecting frequency response is dependant upon which
type of slope you use, it varies with Butterworth or LR slopes, as examples.
There are other ways of setting crossover points though.
For example, if you have T39's, you'll notice in the SPL charts that T39's have a rising response from around 70Hz. You might want to utilise that, so you might set a subs low pass at say 60Hz with a 12dB slope, and leave your tops/mains high pass as suggested earlier.
If this hasn't helped, give us more information about what you want to know...
