Lab 15 - 4 ohm - Buyout Special
kkip
#1 Post by kkip »
If you can live with the 4-ohm version of the Lab 15 and don't mind the 27 lbs weight, Parts Express has a "Buyout Special" on the Eminence LAB 15/4 for $198.80. Or buy 4 for $178.80 each.
http://www.parts-express.com/eminence-l ... m--299-391
Seems like a pretty good price considering the 8 ohm version is currently $284.99.
1 x TAT - GTO804
Re: Lab 15 - 4 ohm - Buyout Special
#2 Post by Grant Bunter »
kkip,
The regular Lab 15 is a 6 ohm driver, not 8.
And I can't recall for the life of me if the Lab15 4 has a reduced voltage limit, compared to the 6 ohm version...
kkip
#3 Post by kkip »
Grant Bunter wrote:kkip,
Good catch Grant. Also, on closer inspection, I noticed that the TS parameter are quite a bit different on the 15/4 model as well. For example, Fs is 34 Hz on the 15/4 and 28 Hz on the regular 15. The Qts is .51 on the 15/4 and .35 on the regular 15. So anyone interested in using this driver would need to carefully check their plans against these specs first.
1 x TAT - GTO804
