2 Dual T60's - Go hard or go home!!
Posted: Wed Mar 18, 2015 11:32 am
I've been enjoying my autotuba for a number of years and now its time to start building again. I've had the drivers for a few projects collecting dust however pesky little things have been holding me back. Little things like losing my house twice due to floods, numerous surgeries and then to top it off I broke my right hand really good last summer. Well as luck would have it there seems to be a dwell in my misfortunes so I'm going to leap into this build before disaster strikes again.
My main goal is to replace/decimate 2 SRX728 boxes we have at the club. They did us well over the last 9 years however it wasn't until the kids started showing up with their PK rigs that it became apparent how weak they are, especially really down low. Knowing how much more articulate horns are over front loaded boxes, tubas I believe are my answer.
[spl width =650&height=450&fmin=20&fmax=120&dbmin=85&dbmax=125]T60W15DLab12+12,T45W24DLab12+12,T60W30DLab12X2+6,JBLSRX728+9[/spl]
In that chart I'm comparing 4 lab12 loaded tubas vs 2 srx728's. I added 3 dB's to the srx's because they can handle 80 volts ( 1 dB penalty for compression) vs 50 volts for the tubas. I know the SRX's can take 160 volt peaks in a live setting, but with EDM sine waves, 80 v is as high as they go safely. I'm really surprised by the T45 graphs. That peak at 35hz is astounding! If I were building subs that needed to be mobile then those are what I would build. However, this will be for a permanent'ish install, so go hard or go home, T60's it is!
My hardest decision was whether to go 4 slims and build them into the stage or not. Although it would be a super clean look, I'm hesitant on not being able to move them around or being able to add more to the pile if I need more output. In our club we have a major (+16 dB) resonance at 45 hz and being able to put the subs at the right spot in the no-go zone really helps with that as pulling 45hz out with EQ takes the life out of the music. They'll be in the way now on top, but at least I'm not committed to one spot and can build more if necessary for more output. That decision might come back to haunt me because now "artists" may insist on moving the subs to where they "look" better during shows. I guess you can't win them all.
I really wanted to go 39" wide dually's, but that dream was crushed as soon as I realized that my crosscut sled doesn't go that wide and with 5x5 sheets, cutlist tells me there wouldn't be efficient use of wood.
So with all the decisions made, 2 dual T60's @ 29" width it is!
