Amp selection for T24
Posted: Thu Oct 09, 2014 8:56 pm
I've decided that my first build will be a T24. I've read through the plans a couple times which made me start thinking about driver selection and how to power em.
Quick background. The T24 (hopefully plural) will complement a pair of JBL Eon 515xt's that we have on a rental rig. We find the built in mixers and look to be attractive to the rental world. The JBL's by design have no low end, they roll off around 100 Hz. Our mentality in regards to rental is that it has to be simple. We are trying to keep a rack full of equipment from intimidating anyone or scaring them off. It would be our desire to rent out the T24's. I certainly understand that placement is more important with horn loaded subs, but really feel like some sub is going to be better than no sub if a renter would setup it up in a non ideal fashion.
I'd like to build with the BP102 driver for starters. Primarily for initial (or replacement) cost. I plan on building 2 single driver cabs for starters. I currently have no amplifier or processing equipment for these subs. I've been considering getting a lower power, 2 channel amp and running each driver on it's own channel. Something like the Crown XLS1000. My thought process was to use the on-board crossover to low pass the signal at 100 Hz and utilize the amplifier max output to limit the power to the speakers. I believe that whether I choose a 4 or 8 ohm driver would factor into this equation. My goal would be to prevent overpowering the drivers and prevent the need for additional processing. It looks like if I chose the 4 ohm driver and the 350w @ 8 ohm XLS1000 my max voltage would be 37V (or do I need to figure this at 6 ohms?). If I chose the 8 ohm driver at 215w I would expect 42 volts. If that is an appropriate way to evaluate that, I'd choose the 8 ohm driver. What other factors do I need to consider and what amp do you think I should choose?
I'm certainly new to this world and looking to learn. My goals for this initial project are to compliment a small DJ setup for weddings, parties of up to 300 people. I'd like to avoid additional processing for complication and cost reasons. (I also want to know if that is a big mistake)
