Page 1 of 2
Thinking of getting a DEQ2496. What else do I need?
Posted: Tue May 20, 2014 7:36 pm
by jimbo7
I found a DEQ2496 for $200 obo. Barely used but with no mic. I'm seriously debating getting this (although my wallet scream no). What else would I need, like cables, manuals, software, hardware? I'll be running 2 SLA's and 1 T24 for the time being. All 3 speakon connectors. Mixer is unbalanced RCA's, amps have bananas, 1/4" and speakons.
Re: Thinking of getting a DEQ2496. What else do I need?
Posted: Tue May 20, 2014 7:39 pm
What are you using this setup for? That will determine what you need.
Posted: Tue May 20, 2014 7:48 pm
by jimbo7
Mainly for my own contentment, but parties and hopefully small gigs in the future. Mostly indoors, but I'd like to do some "drive-in" movies soon.
Posted: Tue May 20, 2014 8:50 pm
by dswpro
Buy it. That's a good deal.
You will need audio cables but go to monoprice.com or Amazon and get some cheap ones.
You don't need software and the manual is on-line for free. You can buy an RTA mic or another mic with a reasonably flat frequency response. I use an AKG C2000B which I know has a slight rise in high end response, so I just take that into account. I don't "auto-tune" my system, I read the response and adjust the EQ manually. More important if you are considering playing really loud is a system controller / digital crossover.
Posted: Tue May 20, 2014 11:10 pm
Posted: Wed May 21, 2014 2:34 am
by Grant Bunter
Get it.
Being able to RTA later on is very handy.
This isn't relevant to having a DEQ.
At least as far as the amp goes, seems you are talking about the output side of the amp.
Is that the case?
What is the input connector for the amp?
Your chain would become mixer---> DEQ--->amplifier--->speaker cabs.
Later, after you have built sub 2, you then need to add DSP, and if you want to run your SLA's in stereo, another amp.
Your chain would then become mixer---> DEQ--->DSP--->amplifier--->speaker cabs.
At that stage, I would disconnect the inbuilt filters in your T24, as the DSP will do that task better...
Posted: Wed May 21, 2014 8:55 am
by whines
+1, I got the Dayton one and it works great with my used DEQ.
Posted: Wed May 21, 2014 7:27 pm
by jimbo7
Grant Bunter wrote:What is the input connector for the amp?
I'm using the 1/4" input connectors with RCA-to-1/4" adapters since my mixer is RCA only. The amp is a Carvin DCM1000 and has all the most needed input connectors.
Grant Bunter wrote:Your chain would become mixer---> DEQ--->amplifier--->speaker cabs.
Later, after you have built sub 2, you then need to add DSP, and if you want to run your SLA's in stereo, another amp. Your chain would then become mixer---> DEQ--->DSP--->amplifier--->speaker cabs.
My next buy was another amp (till this came up). I thought the DEQ2496 does dsp, too? I'd like to keep the passive crossovers in the SLA's incase I ever use them for something else.
FYI The mixer is connected to my laptop and turntables
Posted: Wed May 21, 2014 10:56 pm
by Grant Bunter
You would need different leads to use the DEQ as that unit has XLR inputs and outputs.
Find something like this:
http://www.ebay.com.au/itm/NEW-2M-Stere ... 775&_uhb=1
at a store nearby, or local e-bay, etc, to go from mixer to DEQ.
It would also be better if you used XLR to XLR leads from the DEQ to the amp as XLR's lock in place, meaning no accidental disconnects possibly causing harm to your system.
No, the DEQ 2496 is
not a DSP unit. Behringers version of DSP is the DCX2496.
Sure. Great idea.
I was saying bypass the filters in your T24's, not the SLA's...
Posted: Thu May 22, 2014 12:02 am
by DJPhatman
jimbo7, you need to be using an active crossover, not a passive one, from the SLA to the T24. You should make any passive crossover in the T24 defeat-able, so you can run your system properly. I think you should look for a DCX2496 first, and not worry about the DEQ2496 right now. The DCX2496 is way more important, as it has a limiter and crossover, plus enough EQ to make your system sound good.
Posted: Thu May 22, 2014 12:25 am
by Grant Bunter
DJPhatman wrote:jimbo7, you need to be using an active crossover, not a passive one, from the SLA to the T24. You should make any passive crossover in the T24 defeat-able, so you can run your system properly. I think you should look for a DCX2496 first, and not worry about the DEQ2496 right now. The DCX2496 is way more important, as it has a limiter and crossover, plus enough EQ to make your system sound good.
+1
Posted: Thu May 22, 2014 8:18 pm
by BrentEvans
Grant Bunter wrote:
No, the DEQ 2496 is not a DSP unit. Behringers version of DSP is the DCX2496.
Technically, DEQ2496 is a DSP (digital signal processor) device, it simply is limited to EQ, FBD, limiter and Delay.
Not all DSPs do the same thing. Something like the DCX or DRPA or Protea is a DSP too... but it has crossover slopes in addition to the delay and some EQ. Then you have something like the Symetrix Solus which, being fully open architecture, blurs the lines between a crossover DSP and a digital mixer.
Posted: Thu May 22, 2014 8:53 pm
by Grant Bunter
Brent, you're quite correct.
A number of us, through various threads the OP has put up, have been suggesting he get a DSP unit such as the DCX or Driverack.
Sure, the DEQ has a limiter. It's a dynamic limiter (who's intended use is not brick wall limiting), and, while, at a stretch, one could argue that may be sufficient to limit, it's not what we ordinarily recommend for that purpose, right?
For simplicity I said the DEQ is not DSP.
Instead of, "The DEQ is not the required DSP for the job at hand. The DSP from Behringer for the job at hand is the DCX 2496."
Posted: Thu May 22, 2014 9:17 pm
by BrentEvans
Agreed
The additional accuracy gained from the second explanation is worthwhile, IMHO.
Darn Behringer and their model numbers. Today I worked on a system with "DSP1100" units... which is a parametric EQ and Feedback destroyer combo. At least the DEQ and DCX are more descriptive.. DEQ = Digital EQ, and DCX = Digital Crossover (CX being one of those weird abbreviations when X taxes the place of a part of the word...)
Posted: Sat May 24, 2014 12:52 pm
by jimbo7
I'm happy to recieve the information I greatly need on the subject(s), but sad this deal is not for me. Your help has saved me money and many sorrows.
I guess I'll look towards getting the DCX or PA+, instead.
