16" THT: testing new Dayton mobile phone mic
Post links to youtube videos of your cabs.
Forum rules
SRTnewb
#1 Post by SRTnewb »
https://www.youtube.com/watch?v=lP1MKs8WBv8
Peak of 8V. -20db, +3db trim
Re: 16" THT: testing new Dayton mobile phone mic
#2 Post by Tom Smit »
Oooo, should be good! How are you liking it?
SRTnewb
#3 Post by SRTnewb »
The THT or the Mic?
THT: I'm loving it! I re-wired it parallel instead of series and it pounds with MUCH more authority.
Mic: It records loud sound surpringly well for being soo small. I'm not sure if I loaded the calibration file correctly on my phone as I cannot get the thing to register anything higher than 103db. It supposedly reads to 127db. All I can get is 103db at the couch. I thought that seemed quite low so I put it at the mouth..103db.
MissileCrisis
#4 Post by MissileCrisis »
You need to set the "reference point" for the mic. It doesn't measure absolute spl's like an SPL meter does.
If you're using REW (room equalizer wizard) then you can do the following:
--click spl meter (button/icon), click calibrate
-- follow instructions that they give you (Something along the lines of adjust the spl here so that it matches your SPL meter. Then you will be able to measure +- 10-15 dB from that "reference point" based on the dynamic range of the mic.
Note:
This is how you can get a "unweighted" result using a combination of SPL meter and mic. You use a test tone at ~60-80 Hz on the C-weighted SPL meter to set the level of the mic and then use the mic on Z-weighted/unweighted to measure the music/sound. If this doesn't make sense let me know and I can try to clarify.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
MissileCrisis
#5 Post by MissileCrisis »
SRTnewb wrote:The THT or the Mic?
I would be worried here, wiring a 4 ohm dvc into 2 ohms can kill some amps. tread carefully.
2 x TLAH
SLA Center
1 x 212 TH (custom)
ripNdeb
#6 Post by ripNdeb »
Too many words for old folks. Can you actually understand the words??? Bass is hard to determine for IPhone or camera or what ever was used. But, I'm sure if it was Bill designed to spec it's awesome :hyper:
SRTnewb
#7 Post by SRTnewb »
So after a few drinks one day I decided it would be a good idea to play a 15hz sine at god knows what voltage..it lasted about 5 seconds. Now my amp won't even power on. Picked up a cheap 235w plate amp for the mean time and the beast is back up and running.
Also, yes..I can understand the words and the bass is glorious. If you watch the video with a pair of good headphones it sounds a little better.
