My week at The Dorset Steam Fair with an LS9 and some EAW.
Posted: Sun Sep 15, 2013 1:43 pm
I worked the Micheal Oliver stage at the Great Dorset Steam Fair. It was very interesting and nice to do something different.
A great bit of kit as it pretty much provides everything you're ever likely to need in 90% of situations. Flying faders, Automation, built in Graphic EQs, Multi FX units, Save and re-call facilities, Comprehensive dynamics on everyin in / out etc..
Facilities:
An almost overwhelming array of options allowing a completely custom setup if required. The 'standard channel' has a four-band fully parametric EQ plus a variable hi-pass filter. There's two dynamics 'slots' which can be assigned differently for every channel but for my setup I simply chose and normal gate and a normal compressor although there's options for a de-esser, an expander amongst others. 14(?) Auxes can be be pre / post fade and the outputs of each can be routed via the 'Rack' which is a virtual rack of any of the internal processors if required. I used the 31 band graphic EQs on my monitor (Aux 1-4 - Rack 1 - 4) and three multi FX units for Short reverb, Long reverb and tap Delay. A maximum of 4 units accross 2 racks can be used. My final slot was the Flex 15 EQ for FOH which is a 31 band EQ but you can only use 15 of the bands. Sounds wierd but is actually ok to use. I'd be worried if I needed more than 15 bands. The Graphic EQs can be assigned to the faders allowing adjustments of the frequency bands per fader. Very clever! Input gain is metered in the usual way with use of the 'cue' button showing the level on the main meter although there are channel meters in LEDs on each as a peak meters fo quick reference. I could go on but I'd be here for days! One last thing to mention is lack of groups as everything is routed on 'omni-out' 15-16 which is what we'd call LR master out. Custom fader layers could be used to emulate groups but in the end I didn't bother as it added uneeded complications.
Sound integrity:
Not bad but not quite as 'transparent' as i might have expected from such a console. The FX and dynamics have very comprehensive controls with more than you're likely to need and work very well as does the EQ. Maybe it's the LR buss but I felt like it was all a bit 'contained' so to speak. From a sonic perspective I believe my Soundcraft to be superior.
User interface:
Isn't bad but simply cannot keep up with the massive facilities that the desk offers. It's often too slow to get to where's needed quickly requiring many button presses and menu flicks to get from one page area to another. The direction keys and jog-wheel next to the display are the main way around the desk. The shortcut buttons help but even so, it's still not good enough as you can choose which button goes where. This was a real ball ache to setup but helped once it was. The lack of touch screen and small display are what limit the desk and it's abilities although I understand they can be remotely setup so can be used at a distance via an Ipad which would be much better probably. The 'home' button is very handy for taking you back to which ever 'layer' (1-32, 33-64, master or custom). A stripped down M7 is the best way to compare the LS9.
Conclusion:
I tried all week to find some love for the Yamaha but I simply couldn't muster any. I did nearly 40 shows in 6 days but I found the interface too fiddly to get to some things, usually when I needed them! As such, I wouldn't buy one insspite of the many facilities.
Anyone else used one and wishes to share?
Facilities:
Sound integrity:
User interface:
Conclusion:
