1st AutoTuba Build
Posted: Tue Jun 25, 2013 8:33 am
by DrFunk
Just bought the Tang Band W8-740P at parts-express. Will be starting and completing this over the long 4th of July weekend. Only need to find some BB around Charleston and I'll be good to go.
Re: 1st AutoTuba Build
Posted: Tue Jun 25, 2013 12:17 pm
by J_Dunavin
What amp are you using?
Posted: Mon Jul 08, 2013 12:39 pm
by DrFunk
Sorry for the late reply. Using this:
http://www.crutchfield.com/S-qFRGI241Tr ... 4-0-2.html
Just started today with some basic cuts. Something mildly unfortunate is that only 3/4" was available (arauco), so I have that. Where should we adjust for difference (1/2") in thickness?
Posted: Mon Jul 08, 2013 11:39 pm
by 67baja
DrFunk wrote:Where should we adjust for difference (1/2") in thickness?
At the lumber yard. Get 1/2".
Posted: Tue Jul 09, 2013 1:59 am
67baja wrote:DrFunk wrote:Where should we adjust for difference (1/2") in thickness?
+1
That way you won't have to compensate for the extra thickness.
Posted: Tue Jul 09, 2013 7:48 am
by DrFunk
The blatant sarcasm and unhelpfulness echos loudly. Perhaps you didn't read my post, but that was all that was available at the time and therefore it is what I have to work with. Yes, I knew 1/2 was what was needed, however there was no 1/2 available.
Posted: Tue Jul 09, 2013 9:14 am
DrFunk wrote:The blatant sarcasm and unhelpfulness echos loudly. Perhaps you didn't read my post, but that was all that was available at the time and therefore it is what I have to work with. Yes, I knew 1/2 was what was needed, however there was no 1/2 available.
Everyone was trying to be helpful and you mistook humor for sarcasm. The point is - if you want a chocolate cake, you don't substitute strawberries for the chocolate....do you?
To say that there is no 1/2 inch plywood available is hard to believe. Your location isn't listed, but you mentioned you are near Charleston - a couple of phone calls would probably find you some suitable material.
If you are serious about making a quality speaker that performs as it is intended - then you should go the extra mile to do it right. You won't find many here who will encourage you to do it wrong and help you in that endeavor.
Tell us where you are and maybe someone nearby can suggest a supplier.
Posted: Tue Jul 09, 2013 9:19 am
by Ryan A
Using 3/4" would change the horn throat area quite a bit and also changes the flare of the horn slightly...its hard to say exactly how it will affect response but give it a try if you wish.
If you're going to use 3/4 (which I wouldn't), try to make the horn's inside dimensions as close to the original as possible, which means adding 1/4" here and 1/2" there to the inside dimensions so as not to remove horn area from the design.
This is not a recommended practice, but you asked...
Posted: Tue Jul 09, 2013 9:40 am
by 67baja
Okay, sorry about the tongue-in-cheek attempt at humor, but I meant what I said. Call cabinet makers in your area and ask where they get their BB plywood. Also, add your location so someone here can recommend a lumber yard that has BB. You *could* use 3/4", but that is a huge waste of time and energy. These cabs were engineered to use 1/2", the plans were designed and drafted around 1/2", so it is HIGHLY recommended to use 1/2"! 3/4" ply will add 50% more weight to the box, plus you can no longer use any of the dimensions in the carefully produced plans. And, the finished product may not work as it should.
Posted: Tue Jul 09, 2013 10:35 am
Apologies. No sarcasm meant. But the truth was told.
If you want you can use 1/2" plywood, 5 ply. Spruce, pine, fir. As long as it free of voids, or they are minimal, it will work. I've used it several times.
Posted: Wed Jul 10, 2013 11:02 am
by Radian
If you find some 1/2" but are still compelled to make use of the 3/4" you have on hand, how about using it for the outer panels and using 1/2" for the insides?
It'll be complete over-kill as I'm sure you'll figure out once you're under way, but at least the wood won't go to waste and you'll still end up with a horn path that's within spec.
Posted: Wed Jul 10, 2013 12:28 pm
by subharmonic
DrFunk wrote: Only need to find some BB around Charleston and I'll be good to go.
South Carolina? If it is you are telling us in a metro area you can't find the right wood. Our town is 1/2 the size of yours and in BFE and we still have multiple sources for wood. I would recommend trying a little harder or there is not much point to the build as it will be a crap shoot.
Posted: Wed Jul 10, 2013 3:03 pm
by MissileCrisis
Holy crap I just laughed so hard. Never seen bfe so I had to look that one up. Anyways I agree, unless you live in sub-saharan Africa or in other words bfe you should be able to find half inch. Even if it has warp and knots it will be less frustrating than if you build out of 3/4 and screw up an internal dimension.
Posted: Wed Jul 10, 2013 3:09 pm
MissileCrisis wrote: Never seen bfe so I had to look that one up.
They just don't teach these kids nuttin' in school anymore.
Posted: Wed Jul 10, 2013 5:09 pm
by MissileCrisis
Haha. I work with a bunch of PhD engineer and scientists so I'm used to not knowing things.
