Page 1 of 2
Yung plate amps?
Posted: Tue Apr 09, 2013 9:51 pm
by thunderw0lf
Anyone here had any experience with these? Parts Express is selling them for a little less than the Dayton and Bash amps. The little bit I've read on them from users says they tend to have a bit more power in the low frequencies where the others start running out. They also have variable phase and boost or no boost models.
http://www.parts-express.com/cat/subwoo ... /332?m=488
Re: Yung plate amps?
Posted: Thu Apr 11, 2013 9:45 pm
by Ryan A
thunderw0lf wrote:Anyone here had any experience with these? Parts Express is selling them for a little less than the Dayton and Bash amps. The little bit I've read on them from users says they tend to have a bit more power in the low frequencies where the others start running out. They also have variable phase and boost or no boost models.
I'm using the 200 watt (35hz @ +6db) version for a home theater horn and I've had very good luck with it so far. The auto power on feature is very nice and works great.
Posted: Sat Jul 06, 2013 10:43 am
by Bman
Using the 300W, no boost version with my TAT. I've had it for just about a year now. Use it quite often. Works awesome. Plenty of power. Never really had to really go past half volume. Once I had it running for about 10 hours straight (long extended family party). Didn't break a sweat and just got mildy warm.
Posted: Sat Jul 06, 2013 11:45 am
by bassmonster
Anyone have a Yung amp and a Bash 300? How do they compare?
Posted: Tue Jan 07, 2014 9:40 pm
by bossman
Anyone used these yet? I see they are on sale at PE for a reasonable price. Was looking to pick up one of the 500w models to power a TT.
Trying to decide whether or not to get the one with the 6db boost.
Posted: Tue Jan 07, 2014 10:40 pm
by sine143
they both have filters around 25 to 30hz iirc
Posted: Wed Jan 08, 2014 10:26 am
by Ryan A
They work great. I got the one with +6db @ 35 hz to compensate for the falling response of the horn and because I like a nice fat bottom. Its personal preference really. +6db is no small gain though so make sure you really want it before going that direction.
They have no official subsonic filters, but a built in automatic limiting circuit which works very nicely. They dig as deep as you'd need or want.
Can't comment on the Bash comparison, don't have one.
Posted: Wed Jan 08, 2014 2:59 pm
by sine143
Ryan A wrote:They work great. I got the one with +6db @ 35 hz to compensate for the falling response of the horn and because I like a nice fat bottom. Its personal preference really. +6db is no small gain though so make sure you really want it before going that direction.
The boost models moste definitely have a filter. the boost is the product of a hi q filter.
Posted: Wed Jan 08, 2014 3:23 pm
by Ryan A
That's a different filter, I was talking about a subsonic filter.
Posted: Wed Jan 08, 2014 3:31 pm
by sine143
Posted: Wed Jan 08, 2014 3:51 pm
by Ryan A
I'm just saying they don't mention having a subsonic filter anywhere. If response dips below 20hz that's fine with me as it protects my speakers.
Wonder if there are any actual charts of the non-boosted models
Posted: Wed Jan 08, 2014 3:53 pm
by sine143
response dipping below 20 is a subsonic filter.
I didnt see any non boost charts, although there is a graph of someone who both modified the hipass, and removed the boost circuitry (puts it about 1 db down at 20 with a 12 db oct slope)
Posted: Wed Jan 08, 2014 5:37 pm
by bossman
That's a lot of great information.
I was looking at the SD500 since that's the one on sale at PE right now. From the charts that sine143 provided, it looks like the 500 has a boost at 25Hz and the 200 has the boost at about 35Hz.
Do you guys have any thoughts on using the boosted SD500 vs non boosted SD500 for a Table Tuba?
Posted: Wed Jan 08, 2014 6:13 pm
by Ryan A
25hz is too low for the TT to have a 6db boost. You'd risk damaging the drivers easier. I'd go with the unboosted version.
What drivers are you using for the TT? 500 watts is too much for a single driver build most likely, dual premium 8's or 10's would be fine.
Posted: Wed Jan 08, 2014 6:48 pm
by bossman
I have another HL10c I will be using for the TT. The plate amp is rated for 500w @ 4ohms but the TT will present an 8ohm impedance. I estimate the amp will have closer to 300w output with that load so I don't think it will be grossly overpowered.
Sounds like the non boosted version will be better - I don't want to kill the driver.
