Behringer A500 bridged for a T-60?
Posted: Fri Mar 01, 2013 2:58 pm
by joeybutts
I was thinking of picking up an A500 used from a guy and was wondering if I can run it bridged on a T-60. I figured that would be a great fit for the horn.
Correct me if I am wrong please! Thanks!
http://www.parts-express.com/pe/showdet ... er=248-749
Re: Behringer A500 bridged for a T-60?
Posted: Fri Mar 01, 2013 3:15 pm
by Ryan A
You can, but its really made for home audio. Pro sound amplifiers have a high duty cycle able to run continuously at high power levels. This amp may or may not be up to the task. For a house party setup its probably fine, but I wouldn't use it for a mission critical pro sound application.
Posted: Fri Mar 01, 2013 4:28 pm
by joeybutts
Ryan A wrote:You can, but its really made for home audio. Pro sound amplifiers have a high duty cycle able to run continuously at high power levels. This amp may or may not be up to the task. For a house party setup its probably fine, but I wouldn't use it for a mission critical pro sound application.
Thanks Ryan. I do plan on using this sparingly (working in the yard, occasional party, yada yada). I can get the amp for $100 shipped so figured it was well worth the price.
Is there anything else I should consider for the price? I can also get a Dayton 240 for about the same, a little cheaper....
Posted: Fri Mar 01, 2013 6:01 pm
by Grant Bunter
Posted: Fri Mar 01, 2013 6:39 pm
by joeybutts
Grant Bunter wrote:You may wish to read this:
http://billfitzmaurice.info/forum/viewt ... ng#p208276
Thanks Grant. I'll take your cue as a "find another amp to use." :bash:
Posted: Fri Mar 01, 2013 6:47 pm
by Grant Bunter
joeybutts wrote: Thanks Grant. I'll take your cue as a "find another amp to use." :bash:
:clap:
Honestly, some bridge, others don't.
If you can find something at a reasonable price you don't have to bridge, well, IMO, that would be better...
