TLAH Pro quadrilateral version
Posted: Sun Sep 30, 2012 11:00 am
This is the continuation of a quadrilateral TLAH Pro build. Apparently the
forum software saw fit to purge ALL of my previous build thread ...including
the photos leading up to this point
To recap, I wanted a free standing TLAH Pro version. However this build
was started before BF released his rectangular version of the TLAH Pro.
So after some discussion on the forum, I had opted for a squared front
and back with tapered sides. The transmission line vents at the bottom.
The biggest errors I have made thus far is with the filling, sanding, priming
and finishing of the project. It came out much more rough looking than I
would have liked.
There were also some construction considerations related to the shapes
of both the tweeters and the midwoofers. The tweeters Dayton Audio ND20FB-4
are a tapering cone. Almost imperceptiably so, but it sure does become
noticable after trying to fit them into the holes you just finished boring
based on the diameter of their round face! By the way, NO I did not pay
the current price for those tweeters. They were less than $6 apiece back
when they were purchased. The midwoofers are of the recommended
pincushion style to facilitate close center to center placement. But the
underside of the face plate is not flat. The factory provided gasket conceals
a tapered bump that ruins a flat / flush mounting. So off the gaskets went.
The best solution to both problems seemed to be a quality silicone sealant
...and it worked rather well. The only issue is that the tweeters are not 'glued'
into place and may require something additional to make sure they are
secured in place.
The first photo was from when the midwoofers were individually tested to
make sure their polarity and +/- markings were correct ...they all were.
The second photo shows the approimately 3/8" - 1/2" bead of silicone used
to properly seal the midwoofers.
The third photo is with all the drivers mounted and most of the excess silicone
already trimmed away.
I wanted to repost the T/S parameters for both drivers as I will have some
questions concerning the wirring and cross-overs. I was not able to find any
graphs for the midwoofers.
Dayton Audio ND20FB-4 Rear-Mount 3/4" Neodymium Dome Tweeter
VCdia: 3/4"
Impedance: 4 ohms
Re: 3.2 ohms
Le (mh) @ 10Khz: 0.03
Fs: 2072 Hz
Qms: 2.08
Qes: 3.74
Qts: 1.33
Sd (cm2): 2.8
VC dia. (mm): 19
SPL: 93 dB 2.83V/1m, 90 dB 1W/1m
Frequency range: 3,500 - 25,000 Hz
Power handling: 15 watts RMS/30 watts max
Overall diameter: 1-9/16"
Cutout diameter: 1-7/16"
Depth: 1/2"
Samsung 10W72BRA / Atlantic Technology 350-3171 A309-28
4" Poly Cone Shielded Midbass
Poly cone w/rubber surround, Treated cloth dust cap
1" VC with aluminum former, Magnetically shielded
*Power handling: 40 watts RMS/80 watts max
*VCdia: 1.0"
*Le: 0.6 mH
*Impedance: 8 ohms
*Re: 5.3 ohms
*Frequency response: 100-8,000 Hz
*Fs: 105 Hz
*SPL: 88 dB 1W/1m
*Vas: 0.11 cu. ft. / 3.11 liter
*Qms: 4.16
*Qes: 1.03
*Qts: 0.826
*Xmax: 3 mm
*Efficiency bandwidth product (EBP) = 101.94
*Sd [Calculated]: 54.078 cm2
*Vd [Calculated]: 16.22 cm^3
*Dimensions: A: 4-1/4" (5-1/8" diagonally), B: 3-3/4", C: 2-5/8"
*Driver volume displacement (for 0.75" baffle thickness) = 166.43 cm3 / 10.16 in3
{speaker measurements: Dc 8.3cm, Md 5.8cm, Dm 7.8cm, Hm 3cm, Xmax 0.3cm}
would have liked.
secured in place.
VCdia: 3/4"
Impedance: 4 ohms
Re: 3.2 ohms
Fs: 2072 Hz
Qms: 2.08
Qes: 3.74
Qts: 1.33
Sd (cm2): 2.8
VC dia. (mm): 19
Depth: 1/2"
*VCdia: 1.0"
*Le: 0.6 mH
*Impedance: 8 ohms
*Re: 5.3 ohms
*Fs: 105 Hz
*SPL: 88 dB 1W/1m
*Qms: 4.16
*Qes: 1.03
*Qts: 0.826
*Xmax: 3 mm
