Been super busy here, Just working
Mid December I had to do sound for my wife's expo,
http://www.healingpathexpo.com , in a pavilion down the road from us. This is the 3rd year, and never been happy with the sound til this year.
The room is 'L' shaped, all beautiful wood floor to ceiling, and one side a wall of windows. NO sound absorbing anywhere, a sonic nightmare.  You drop a pin in 1 corner, you hear it at the other end. Luckily, no music this year, just 14 speakers over 3 days.
The speakers where in the short section of the "L", vendors and food in the long section.  To add to the problem, she preferred that the speakers wouldn't bleed into the vendor area.
Have used a couple Mackies in the past years, with mediocre results. At least mediocre to my ears, the people were happy
   Not covering as evenly as I would have preferred.
This year, I tried the J10's, and the results were pretty much the same as the Mackies, too much projection,  too much bleed.  Decided to try something new.
I put Top Hats in the Wedgehorn 8's, as shown in the picture.  Did a bunch of measuring beforehand, to be sure there where no obstacles, of course
   Drilled the holes, cleaned up the inside, put in extra batting, and installed the top hats. Put two rings of PL around the hole before installing, so no air leaks.  After the screws were in and the PL cured, took out the screws and filled the holes with PL, and reinserted the screws.  Been too busy to even put on the Duratex, but since they get used so rarely, black paint is fine.
I figured even if they didn't work for what I needed, having stand mount monitors may be useful anyway  ....
The results were beyond my expectations. After some RTA time, a day before the expo,  I fired them up with some music I was very familiar with (Early YES Albums), and walked around the pavilion. Except for some lacking bass end, which isn't needed for speakers only anyway, the sound coverage and consistency was the best we have ever had there! The shorter, and as I found out, very even throw from the pair of stand mounted W8's was perfect in the speaker area, with very little bleed into the vendor area.  Even a lot of the attendees that have been there for the last 3 years even noticed the difference.  Even coverage everywhere it needed to be, without anywhere too loud
For kicks afterwards before tearing down, a added a small sub, a single 15" bass guitar cab I had sitting around and biamped the system, and the results were now even great for small room music content...
If you need a 'small room' PA without building a second set of cabinets, try your wedgehorns....
Happy New Year
Don
