Trapping the DEQ between other components may be the source of heat build up. I'd fan cool the rack.safebet wrote: I notice that the DEQ panel gets hot after a long night, and the heat ain't coming from the Crown.
New WH8
Re: New WH8
Re: New WH8
Drop Greg a line at magnum case works. I was doing behringer thru himdjtrumptight wrote:Leland do you still sell DEQ 2496's ?
Re: New WH8
Thanks Leland.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
- subharmonic
Re: New WH8
Sounds to me like this may be the best PA to home audio candidate out there. Instead of using DRs or Otops. Is there any merrit to the wedges being designed as a nearfield type horn thoughts?Bill Fitzmaurice wrote:If you think they're good build a W6. Mine sounded nice with a 7 band EQ, but
I just added a DEQ2496 to my system and now they're stunning, from a package that's silly small, and with the 2496 FBD they'll take your head off before they'll feedback.
Sorry for the hijack, Ima a privateer.
I need more bass
CW Mcall
I need more bass
CW Mcall
Re: New WH8
Not IMO. Their shape and response are specific for their intended application.subharmonic wrote:Is there any merrit to the wedges being designed as a nearfield type horn thoughts?
- subharmonic
Re: New WH8
I guess I may be reading into that a little too much but wouldn't that lend itself to a home experience? I mean on the sales page it refers to the listener being 6 ft from the speaker, most living rooms would be about that distance. IMO Otops and DRs sound better 20' or so away, I have only briefly listened to build Jon Barnhardts WH(10?) and didn't do a distance test.Bill Fitzmaurice wrote:Not IMO. Their shape and response are specific for their intended application.subharmonic wrote:Is there any merrit to the wedges being designed as a nearfield type horn thoughts?
I need more bass
CW Mcall
I need more bass
CW Mcall
Re: New WH8
It's the EQ curve. These are not designed to be flat - definite mid-range boost to enhance vocal clarity in a live setting......you wouldn't find it very pleasing for a stereo.subharmonic wrote:I guess I may be reading into that a little too much but wouldn't that lend itself to a home experience? I mean on the sales page it refers to the listener being 6 ft from the speaker, most living rooms would be about that distance. IMO Otops and DRs sound better 20' or so away, I have only briefly listened to build Jon Barnhardts WH(10?) and didn't do a distance test.Bill Fitzmaurice wrote:Not IMO. Their shape and response are specific for their intended application.subharmonic wrote:Is there any merrit to the wedges being designed as a nearfield type horn thoughts?
- Jon Barnhardt
Re: New WH8
It is indeed a W10 (one revision old).Bruce Weldy wrote:It's the EQ curve. These are not designed to be flat - definite mid-range boost to enhance vocal clarity in a live setting......you wouldn't find it very pleasing for a stereo.subharmonic wrote:I guess I may be reading into that a little too much but wouldn't that lend itself to a home experience? I mean on the sales page it refers to the listener being 6 ft from the speaker, most living rooms would be about that distance. IMO Otops and DRs sound better 20' or so away, I have only briefly listened to build Jon Barnhardts WH(10?) and didn't do a distance test.subharmonic wrote:Is there any merrit to the wedges being designed as a nearfield type horn thoughts?
+1 to Bruce. The DR's and OT's sound better in a stereo situation. EQ might equalize the playing field (pardon the pun) but in the end, proper tool for the job...
- subharmonic
Re: New WH8
I was really not thinking in terms of EQ since they all need considerable EQ vs a proper home audio speaker....my point/question was regarding the way the speaker throws, as it was designed for a much closer listening postion than a PA speaker.
I need more bass
CW Mcall
I need more bass
CW Mcall
Re: New WH8
Here's my review of the new wedgehorn 8's which Leland built for me. I had a music/magic/comedy show friday and really got to use them for the first time. EQ'd them with the sweepable four band on the presonus board and that was it. Nice sound with no feedback. None at all. All night. High pass around 100 Hz because of the T39 but they will go lower nicely if you need it. Good dispersion and a really pro look, at least what Leland did for me with the grill.
2 SLA PRO (built by Leland)
2 T39 24" 3012LF (built by Leland)
2 Jack 10's (built by Leland)
4 Wedgehorn 8's (built by Leland)
1 XF210 w/Legend 1028 (built by Leland)
Re: New WH8
Thanks! Glad you like them.
Re: New WH8
I put the wedgehorns to use again. This time with the full band. One for the keyboards and one in front fo the rest of the group. These cabs floor me. Tons of headroom. They never get close to breaking up. Great dispersion. Sure, it would be great to have one for each musician but for our situation on mostly small stages, it's not necessary. My keyboardist said it was the best stage sound he has ever had and I have to agree. Kudos to Bill for a great design.
Re: New WH8
Being designed for close range use they don't go as loud or low as those designed for mains usage, allowing a smaller cab. I still wouldn't use them for hi-fi/HT myself.subharmonic wrote:my point/question was regarding the way the speaker throws, as it was designed for a much closer listening postion than a PA speaker.
