Leaks from gasket
Leaks from gasket
How common is it to have a leak at the gasket? I have been testing my jacks and they dont appear to have leaks, but I am not sure I know what to listen for. Is there another way to describe the "chuffing" noise so that I know what how to identify it?
Built 2-OT12 (3012HO); 2-T39 22" (3012LF); 2-T39 16" (3012LF);
2-J12 (DL2512); 2-W8 (Beta 8A)
Re: Leaks from gasket
It's something you just immediately know when you hear it, and it is tricky to describe. I had repaired some vibrating braces on a T30 and there were some very small holes in the top where I was drilling for the panel. The bass was there but less powerful and you could really hear the "chuff"...just air blowing through a little hole...that's what it sounds like.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
bassmonster
Yup, the "pfff pfff" sound is pretty apparent when the leak is on the outside, and it's most apparent at very low frequencies- something just sounds wrong and you know it's not a normal sound. I had the same air leak problem with pilot holes I had drilled and didn't use. Filled with PL, problem solved. Driver gasket leaks are pretty common too- a bead of latex caulk around the gasket as you attach it and helps prevent leaks.
I put the back on and pulled a screw from the jack plate. Now I understand what to listen for. Thanks.
