Build time for 4 DR250's
mobetter
#1 Post by mobetter »
Does anyone have an estimate build time to complete 4 Dr 250's, I understand that it depends on the tools you have and the level experience you have. I have a table saw and most power tools available. and my wood working skills are good. I also know that the use of jigs could also help. I've only have 2 t-48's and 1 t39 under my belt so far as BFM designs go.
I had planned on getting these done months ago but got sent out of town for work. Now that I'm back our band is starting to pick up and i need to get these done. we've been playing some regular outdoor shows and the carvin tops we have been using can't keep up with the 2 t48s.
T39 / OT12 Bass rig
2 T-48
4 DR250, 6 T-48 in the works
lincsoldbird
Re: Build time for 4 DR250's
#2 Post by lincsoldbird »
Hi I would say you could build 4 in about 40 hours but it depends on what finish you want.
built 4 T30 24in BP102 now sold 2 DR280
2 speakerplans 1850, 2 MT102 ,2 X15, 1 G sub now sold
2 T60,s Built plus 4 DR280,s in the build
#3 Post by LelandCrooks »
lincsoldbird wrote:Hi I would say you could build 4 in about 40 hours but it depends on what finish you want.
Uh no. Unless you're completely jigged up and have some experience.
I've done lots of DR's. And have the jigs. I figure 16-20hrs start to finish. That's finished, done nothing left to do. Maybe the new ones are faster, but I doubt it.
doncolga
#4 Post by doncolga »
The DR's are very intimidating to me...but I've only built six easy boxes.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
el_ingeniero
#5 Post by el_ingeniero »
I can only recall seeing your PVC pipe cutting jig, and I know you would have jigs for cutting piezos. Which other jigs would you use for a DR?
#6 Post by LelandCrooks »
Assembly jigs for the horn throats and baffle throat assembly. Plus I built them a little differently than the actual plans. It was a quicker method that burned a lot of plywood. All pretty much invalidated now by the new design.
Drey Chennells
#7 Post by Drey Chennells »
keep in mind Leland's understating a bit 8)
LelandCrooks wrote:[I've done lots of DR's. And have the jigs.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
lincsoldbird
#8 Post by lincsoldbird »
Sorry I did only mean the woodwork bit and I do have a well stocked shop. Handles, corners, painting, etc just runs away with time.
el_ingeniero
#9 Post by el_ingeniero »
LelandCrooks wrote:Assembly jigs for the horn throats and baffle throat assembly. Plus I built them a little differently than the actual plans. It was a quicker method that burned a lot of plywood. All pretty much invalidated now by the new design.
I do like the new design. Looks easier for a newb like me.
DaveK
#10 Post by DaveK »
4 x DR200 took me around 120 hours. That's everything from the first trip to the store for wood all the way to a cab ready to stick on a pole at a gig. It includes jig construction time.
YMMV depending on the level of fit and finish you want. I'm a bit picky about sanding, filling, painting, etc.
