Page 1 of 3
				Re: 4 x Titan 48 24" and 8 x Jack 15 Build
				Posted: Tue Mar 27, 2012 2:03 am
				by Gregory East
				That's adventurous. It sounds like you won't be using recommended Eminence drivers? You may need a lot of EQ to get a respectable sound from the Jack15 if they don't have the required rising response in their midrange woofers, and make you drive them harder to get SPL up.
				Posted: Tue Mar 27, 2012 6:30 am
				by LelandCrooks
				You do nice work.
				Posted: Tue Mar 27, 2012 7:45 am
				by bassmonster
				Clean builds!
				Posted: Thu Mar 29, 2012 4:49 pm
				by Gregory East
				Very tidy.
I hope that lovely looking ply doesn't have a thin veneer face.
				Posted: Fri Mar 30, 2012 8:34 am
				by shawn_g
				Good work. Those are coming along nicely.
				Posted: Sat Mar 31, 2012 6:39 pm
				by DaveK
				Are you sure you can't find a suitable 12 inch driver locally?  It's true that the Jack 15 goes lower than the Jack 12 or OmniTop 12, but it's not any louder.  When you are running with subs, all that low end extension is wasted because the subs take over.  Thus, you are bringing a bigger box that's not giving you any advantage.
The Jack 15 will be nice for small events where you don't need subs, but for that purpose you only need 2, not 8.  If you can find a suitable 12 inch driver, you would be much better off with 8 OmniTop 12 speakers for the big events.
Another thing to think about is your sub-to-top ratio.  For 2000 people, you might be a little shy on bass with just 4 T48s.  You might want to increase that to 8 or even 16 to keep up with your 8 tops.
				Posted: Mon Apr 02, 2012 12:02 am
				by SeisTres
				If you're are planning on multiple smaller rigs for rental/use, then i guess the jacks will work, but as other have said, once you add a sub, the only thing you need is an ot12. It's a much smaller, lighter cab that will give you everything you need as a top.
I have jack10's and ot12's. I takes about two jack10's to equal one ot12. As for the work, price and size of both, it's almost identical. The jack15 will be much more of a match on the spl as a top, the down side will be the much bigger cab.
				Posted: Mon Apr 02, 2012 6:14 pm
				by DaveK
				From you first post, it sounded like you couldn't get suitable 12 inch drivers locally.  If you can, forget about building more than 2 Jack 15s.  Any situation where you need more than a pair of Jack 15s would be much better served with separate tops and subs.  Build a single pair of Jack 15s as your small rig and then piles of T48s+OT12s as your big rig.
				Posted: Sat Apr 07, 2012 12:24 pm
				by ewetho
				What one hole in one brace and three in the other. That's it it's over. Done messed up good now.
Seriously though Nice work. Should be awesome to listen too in the end.
				Posted: Sat Apr 07, 2012 7:28 pm
				by Grant Bunter
				mickeylau wrote:
I need to complete it in another 2 days as my event are nearby.
Joke: why are are you wasting time here then?
				Posted: Sat Apr 07, 2012 8:51 pm
				ewetho wrote:What one hole in one brace and three in the other. That's it it's over. Done messed up good now.
He was joking here.
				Posted: Wed Apr 11, 2012 1:10 pm
				by Michael Ewald Hansen
				Daayumm, that is some fast building man
 Looks very nice..
Im pretty sure they wont sound any loud though, on that last picture!
				Posted: Wed Apr 11, 2012 3:51 pm
				by 88h88
				Blue!
				Posted: Wed Apr 11, 2012 5:40 pm
				by ewetho
				Looks like a good time to soon be had. Yest the first line was a friendly joke on the last post and was meant to make you smile and laugh. Not a biggie. You will really enjoy them when done I am sure.
BTW..  LOOKING NICE!!!
				Re: 4 x Titan 48 24" and 8 x Jack 15 Build (Completed)
				Posted: Wed Apr 18, 2012 11:02 am
				by bassmonster
				Nice!  Liking the natural finished access panels.
mickeylau wrote: the front panel connected to the panel 6 extension and vibrate very hard, I'm worried about weather it can stand for long period.
I think I remember this coming up quite awhile ago.  I think the solution was some stronger bracing, but I don't remember.
