Paint for Plastic Piezos?
Posted: Thu Jan 26, 2012 2:15 pm
by loudsubz
Would model paint work for touching up the piezos? When I glued mine together some glue came out between the joints so I sanded it off and there is some spots that look a little rough and I would like to touch it up. Not sure what is best to stick to the plastic.
Re: Paint for Plastic Piezos?
Posted: Thu Jan 26, 2012 2:50 pm
by Michael Ewald Hansen
loudsubz wrote:Would model paint work for touching up the piezos? When I glued mine together some glue came out between the joints so I sanded it off and there is some spots that look a little rough and I would like to touch it up. Not sure what is best to stick to the plastic.
Model paint should be fine!
http://billfitzmaurice.info/forum/viewt ... zo#p159923
Posted: Thu Jan 26, 2012 4:07 pm
by subharmonic
I used the rustoleum spray paint made for plastic (it has a pic of cheapo plastic lawn chair on it) followed by modelling spray paint. The rustoleum covered the spot filler way better than the model stuff, just like a primer. Did them back to back, no issues yet.
Posted: Fri Jan 27, 2012 3:16 pm
by SoundInMotionDJ
subharmonic wrote:I used the rustoleum spray paint made for plastic (it has a pic of cheapo plastic lawn chair on it)
This stuff is great. I used it on the piezos, DR port rings, and DR port tubes.
--Stan Graves
Posted: Fri Jan 27, 2012 10:38 pm
by loudsubz
Does it also come in a small can so I can use a brush? If not it would be alot of masking or remove the elements from the piezo to paint them.
Posted: Sat Jan 28, 2012 12:31 pm
by subharmonic
Spray paint. I tested on miscut piezos. Barely a trace made it past the phase plug.
Posted: Sat Jan 28, 2012 4:53 pm
by loudsubz
Ended up using speaker cloth instead. Found some on sale and used a piece of corner molding to keep it taught. Had the wife sew the ends of the fabric on the top and bottom so it looked nice and wont fray.
I still need to paint the white molding black, but I think it looks ok.
Posted: Sun Jan 29, 2012 3:03 am
It sure does look OK!
Posted: Sun Jan 29, 2012 7:44 am
by doncolga
I like the cloth covering ALOT. I've seen a piezo stack for OT15's like that. I may do that with mine eventually.
Posted: Sun Jan 29, 2012 8:25 am
by J_Dunavin
Really like that!
Posted: Sun Jan 29, 2012 10:44 am
by Drey Chennells
Nice. The cloth grill lends a different feel. I've had some requests for cloth over the 8mm round steel we normally use.
Posted: Sun Jan 29, 2012 4:49 pm
by AntonZ
I like the look of the cloth over the piezo's, well done.
Posted: Sun Jan 29, 2012 6:40 pm
by loudsubz
All painted up now, just waiting for the duratex
Posted: Sun Jan 29, 2012 7:42 pm
by Drey Chennells
Really nice!
