Cambridge Soundworks Basecube 12 sub plate amp replacement
Posted: Sun Jan 01, 2012 1:10 pm
Thanks in advance for your help.
I've Got a Cambridge Soundworks Basecube 12 powered subwoofer and need to replace the plate amp in it. I spoke to CSW and they will repair it for a flat $175 but the entire subwoofer needs to be sent at an extra cost of $50 for shipping. If I could find a replacement plate amp for around $100+/- that would work as well or better that would be excellent. I have limited electronic experience and therefore defer to the expert advice of this forum. I would be most appreciative for any suggestion or advice for a subwoofer plate amp that will match the specs.
The manual PDF can be found here: http://www.retrevo.com/support/Cambridg ... dj592/t/2/
Amplifier power
(at 100Hz, <.5% THD) - 100 watts
Driver Size - 12 inches
Sensitivity for full output at 100hz
subwoofer level at max
Low pass frequency set at 160 (LFE):
Line Level Input (mono), millivolts - 110
Speaker level inputs (stereo), millivolts - 300
Low Pass Filter Response: 24dB/Octave
Frequency Response, Hz (+/- 3dB):
LP setting
60Hz - 27-58Hz
75Hz - 27-68Hz
95Hz - 28-90Hz
130Hz - 28-145Hz
160Hz - 29-170Hz
It also appears to have a hi pass filter around 30 hz.
I found one suggestion for a Foster WF-100k, but it doesn’t seem this amp is available for sale anywhere anymore.
Hope that’s enough information to start with.
Amplifier power
LP setting
60Hz - 27-58Hz
75Hz - 27-68Hz
95Hz - 28-90Hz
130Hz - 28-145Hz
160Hz - 29-170Hz
