DR200 Comparisons
Locked
DR200 Comparisons
#1 Post by Bill Fitzmaurice »
DR200 with Delta Pro 8 woofer and melded tweeter array, on-axis and 45 degrees off-axis.
DR200 with Delta Pro 8 woofer and dual ASD1001 compression HF drivers, on-axis and 45 degrees off-axis.
The DR200 and the Community XLT43e, a 1x12/horn PA top that retails for $1,029.
The DR200 and the 1x15/horn Mackie SA1521z:
If you're running without subs the Mackie has its advantages, but otherwise there's not a lot to recommend it.
Commercial line array cabs don't come cheap. Here are the DR200 and the $1200 Peavey Versarray 112:
Here are the DR200 and the $2100 JBL VRX932LA:
The DR200 and the $4900 EAW kf730:
Locked
