Setting of the Behringer DCX2496
Posted: Thu Oct 13, 2011 6:15 am
Good Day,
I am just looking for guidance/ corrections, on my current settings of the Behringer DCX2496.
Current setup:CDJ200's (pair)
DDM4000
DCX2496
iNuke 3000 driving a pair of Behringer B1520's
EP4000 (at 4 ohm load, single channel) driving a pair of Behringer B1800PRO's
I have a tiny bit of technical knowledge but havent a foggiest idea about threshold's & limiters. I am just a dumb jock...to make a long story short
I have copied the exact screen readings from the DCX.
Please can some advise if this is correct or can be changed to be better and what the correct threshold, release, limiter, etc values should be for my setup.
forgive me coz i only got the LL settings.
If guidance can be given for setting the iNuke & B1520's, it would be highly appreciated.
Settings as per each screen on the DCX for the EP4000
IN
• INPUT SCREEN IN A Gain: 7.0db
DELAY: OFF
EQ: OFF
DYNAMIC EQ: OFF
THRESHOLD: 0.0db
OUT
• SCREEN 1 of 8
Out Gain: +9.0db
• SCREEN 2 of 8 - X-over pointsType: L-R12 type: L-24
Freq: 80 freq: 158
• SCREEN 3 of 8 – Eq
EQ: ON type: LP
Freq: 80Hz Gain: 1.0db 6db
• SCREEN 4 of 8 – Dynamic eq
Dyn eq: ON type: LP
Freq: 80Hz Gain: -1.4db 6db
• SCREEN 5 of 8 – Dynamic eq (-> dynamics)
Thresh: -15.0db
Ratio: 2:5:1
Attack: 120ms
Release: 367ms
• SCREEN 6 of 8 – Limiter
Limiter: ON
Thresh: -12db
Rel: 407ms
• SCREEN 7 of 8 – Polarity
Normal
• SCREEN 8 of 8 – Delay
Dly: OFF
DDM4000
DCX2496
IN
DELAY: OFF
EQ: OFF
DYNAMIC EQ: OFF
THRESHOLD: 0.0db
OUT
• SCREEN 1 of 8
Out Gain: +9.0db
Freq: 80 freq: 158
EQ: ON type: LP
Dyn eq: ON type: LP
Thresh: -15.0db
Ratio: 2:5:1
Attack: 120ms
Release: 367ms
Limiter: ON
Thresh: -12db
Rel: 407ms
Normal
Dly: OFF
