New Mixer Advice
doncolga
New Mixer Advice
#1 Post by doncolga »
Hey,
You all got me thinking about my Behringer mixer...
I'm thinking about this one as a replacement:
http://www.sweetwater.com/store/detail/MG124cx
Thoughts or comments? Do you think I'll be able to hear a difference? What got me really thinking was that my local music store commented that the A&H's sounded *much* better than others in their inventory (Peavey, Mackie, Behringer). I figured there may be a sonic difference between this one and my current Behringer. As an analogy, I used to think that a guitar was a guitar, until I played a nice Strat...incredible difference. The only mixers I've *ever* used have been Mackies (original CR1604 from early 1990s) and Behringers.
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
BrentEvans
Re: New Mixer Advice
#2 Post by BrentEvans »
I've used both. The yamaha can take a bit more level, and the compressors are decent. As for perceptile sonic quality at reasonable gain levels... not so much. If you went up to A&H, then you might get something.
Doug Hart
#3 Post by Doug Hart »
I've used a lot of Behringer mixers, and I have no problems with them.
Recently, I upgraded a customer's system by swapping out their Behringer mixer for an A&H MixWiz.
Very noticeable difference.
I really didn't think I would hear a difference, but I did, and it was significant.
Doug Hart, Owner
dB Pro Audio
http://www.hartdesignsetc.com
mikeratliff
#4 Post by mikeratliff »
If you are going analog only have look at these, I have used them in the past and they proved to be very solid.
http://www.apb-dynasonics.com
As long as I have been around pro-audio I have never worked with much Yamaha equipment, people swear by it though.
Jon Barnhardt
#5 Post by Jon Barnhardt »
I have an analog 16 ch yamaha. Night and day from any behringer I've ever had. Would like to pick up a mix wiz someday though...
#6 Post by Bruce Weldy »
Jon Barnhardt wrote:I have an analog 16 ch yamaha. Night and day from any behringer I've ever had.
Ditto on the MG166cx - great little board. That's what I use for my band.
Benj Ross
#7 Post by Benj Ross »
I want to check out one of the Yammy boards, but havent had the chance yet.
I recently got an A&H mixwiz version 2 and it is really sweet. Over on gearslutz.com a guy did a comparison with the MixWiz, a mackie 1604 (which I upgraded from), and a mackie onyx I believe, and the difference was pretty dramatic to me. The A&H sounded so much more open and real with an acoustic guitar clip.
I think you will be able to notice the difference with the upgrade.
My .02
Benj
http://www.fofg.org
Peavey and Madisound Dealer
#8 Post by Bill Fitzmaurice »
doncolga wrote:Hey,
You'll outgrow that in short order. Much better:
http://www.sweetwater.com/store/detail/MG166CX/
Pay once, cry once.
doncolga
#9 Post by doncolga »
I've decided on a Yamaha...should be here Friday...woohoo!
Donny Collins
Dan30
#10 Post by Dan30 »
doncolga wrote:I've decided on a Yamaha...should be here Friday...woohoo!
I'm jealous. I need to save up for a better mixer. This 6 channel Behringer isn't gonna cut it. I'm thinking of picking up a Yamaha MG206 when I have more disposable income.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
bzb
#11 Post by bzb »
I have the 124 installed in my rack that I use at 95% of my gigs. I used to have a 166, but sold it after I got the 01V.
I've used the 01V at 2 gigs... not exactly the best ROI yet.
I've had quite a few mixers over the years. Behringer, Mackie, A&H, Alesis, Vestax, Rolls. I've stuck with Yamahas for the last 3 years and couldn't be more pleased with them. You'll be happy with it, I'm sure. Especially if you got it at Sweetwater.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
doncolga
#12 Post by doncolga »
:chainsaw:
I had to cancel my order...tire emergency and one had to be replaced...$200...poof! but at least the ride has safe tires...can't skimp on that.
Anyway...I'll have something to look forward to later. I'll still be going with the Yamaha.
I do have a question though...how are the built in effects on those? I usually use only three effects for my own vocals...hall, room and short delay. From what I can tell, there's no short delay on it...like 50 ms or so. I'm also suspect of any effects that include "karaoke". :?
I was going with the Yamaha without effects and compression only, but the onboard would be handy. Are those worth it, or should I stick with an outboard Lexicon MPX 100 http://www.sixstardj.com/leprompx110d.html that I already have. I'd have MIDI control over it, which would be very nice.
Thanks!
Donny
Donny Collins
doncolga wrote: I was going with the Yamaha without effects and compression only, but the onboard would be handy. Are those worth it, or should I stick with an outboard Lexicon MPX 100
The onboard effects won't have the studio quality of the Lexicon, but for live use you don't need it.
#14 Post by Bruce Weldy »
doncolga wrote: I'm also suspect of any effects that include "karaoke". :?
That's actually one of the better sounding delays...... I thought about painting over the name though....
jswingchun
#15 Post by jswingchun »
+1, I use that delay all the time.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
