And Now For Something Completely Different...
Posted: Tue Jul 26, 2011 12:09 pm
I have my pair of Jack 115's up and running and hosted a party this weekend with a menagerie of folks. I received all sorts of comments from sound clarity to the look of the Duratex.
A few folks were impressed enough to ask some recommendations for a specialty project.
Columbus Ohio has a large group of Bicycle enthusiasts. They advocate bicycle awareness and usage all over the State. There is an organized Co-op for the Bicycle group that organizes parties, display booths, charity drives, etc.
This group is interested in a stereo system that is trailer mounted which can be towed behind a bike. Likely a Pedal-Taxi, so the gearing is low and I would guess a maximum weight limit around 200-250 Lbs.
This is an environmentally motivated group as well, a gas burning gen-set is not an option. This will be run off of lead acid batteries. These can hit the weight limit very quickly.
So, this system will likely 12 volt, obviously depending on how the batteries are wired.
The group has stated they want this as a DJ style setup with the ability to spin vinyl. I think the whole spinning vinyl is the biggest problem. Locating low voltage turn tables and mixers may prove impossible. Perhaps an inverter, but it could kill the juice quick.
A system like this will also need voltage regulators to avoid voltage drops/amperage spikes as the batteries drain, wouldn't it?
Anyway... They want bass reproduction. A horn loaded subwoofer sounds like a logical solution. This site is the home of some of the most sensitive subs available. And a grouping of folks that might be willing to help me think through all this.
1) Trailer Mounted portable, it will not be in operation under movement.
2) 200-250 Lbs weight limit
3) Tops and Subs
4) Low voltage Crossover?
5) Low voltage EQ?
6) Definitely iPod or computer playback
7) Vinyl (Turn tables and a mixer) I'm not seeing a way for this to work though. Maybe an inverter.
Voltage regulation to avoid equipment damage.
I am a general contractor by trade, When I use the term low voltage I simply mean below 110 volt.
I know this is bizarre, but I think some of it is possible.
Thoughts?
Thanks
3) Tops and Subs
5) Low voltage EQ?
Thoughts?
Thanks
