4 DR250s XTi 1000 or 2000?
Posted: Sat Apr 23, 2011 4:41 pm
by TimeWarp
Which amp for 4 DR250s, 2 channels (L & R 2-250s each side)? XTi 1000 or 2000?
How many 250s can safely run off of a 2000?
Thanks
Re: 4 DR250s XTi 1000 or 2000?
Posted: Sat Apr 23, 2011 6:10 pm
by DanielNY
Since the amp will be used for tops (not Subs), you dont need as much headroom. That said, you could safely run two DR250's per side on an XTI 1000. On an XTI 2000 you could get away with four DR250's @ 200w each, I doubt you will need more power than that putting you at 800w and while leaving a little headroom so your not frying your DR's or your AMP.
If by any chance your amp will be used for SUBS at any point then forget about the xti 1000 and go with at least the 2000. Gives you more usage options.
