Page 1 of 3
				My Otop 112 Build (pictures)
				Posted: Mon Mar 07, 2011 11:26 am
				by loudsubz
				Re: My Otop 112 Build (pictures)
				Posted: Mon Mar 07, 2011 11:28 am
				by loudsubz
				Posted: Mon Mar 07, 2011 2:01 pm
				by BoostFab
				great work.
does that vibrating cutter cut fast ?
				Posted: Mon Mar 07, 2011 2:09 pm
				by loudsubz
				BoostFab wrote:great work.
Not really. A jig saw would put it to shame but I like that you can plunge cut with it easily, and the cutting width is very small from the blade so if your making a cutout for a access panel you can have a very tight fit when your cutout is done, with no waste.
Its good for certain jobs but for this one its not on my top list of tools to use, but I still use it once in awhile.
				Posted: Mon Mar 07, 2011 5:10 pm
				by DJPhatman
				Nice work, loudsubz!
I noticed a lot of your cut edges are burnt. Did you buy a good blade? If not, a good blade will make things go a little easier, and the cuts will be cleaner and possibly even straighter.
Have fun, and enjoy the build.
				Posted: Mon Mar 07, 2011 6:59 pm
				by loudsubz
				Thanks!
Its not the blade its the fence. The table saw has an uber cheap fence system and if not clamped on both ends the end closest to the blade tends to bow inwards and puts pressure on the blade as you feed your material through. I have overcome this by adjusting both ends of the fence and clamping the rear seperately, but my partner didn't know about this and was forcing the material through which cause it to burn a lot.
The blade isn't the best in the world, but its an 80 tooth carbide tipped blade which cuts very well normally. I really need to get a good table saw, no mickey mousing anymore.
				Posted: Tue Mar 08, 2011 3:33 am
				by DJPhatman
				loudsubz wrote:I really need to get a good table saw, no mickey mousing anymore
Or, just build a saw sled, and forget the fence.
				Posted: Tue Mar 08, 2011 4:51 am
				by UROK
				Thanks!
Great photos. Totally helpful.
Russ
				Posted: Tue Mar 08, 2011 10:46 am
				by loudsubz
				DJPhatman wrote:loudsubz wrote:I really need to get a good table saw, no mickey mousing anymore
I have 2 saw sleds, but prefer the table saw when I want to rip the boards to the exact width when building the sub cabs. The sled works great for rough ripping.
				Posted: Tue Mar 08, 2011 10:58 am
				by RENDOG
				Nice man....so you found these a little harder than the Titan build?
				Posted: Tue Mar 08, 2011 6:02 pm
				by loudsubz
				RENDOG wrote:Nice man....so you found these a little harder than the Titan build?
Yeah. I like the simple build behind the titans, same width panels just a few different angles. The Otop looked simple to build but takes some time to cut out the smaller pieces and get the angles correct. Nothing impossible I guess it just threw me for a loop. I thought we would be done 4 of them in a day.
				Posted: Tue Mar 08, 2011 7:32 pm
				by DJPhatman
				loudsubz wrote:DJPhatman wrote:loudsubz wrote:I really need to get a good table saw, no mickey mousing anymore
Sorry, I didn't mean to confuse anyone. I meant the table saw jig. Build one correctly, and you will toss your fence away!
				Posted: Mon Jan 23, 2012 7:22 pm
				by loudsubz
				Bunch of updates since then and I finally got around to finishing them up (almost a year now, boy am I slow
				Posted: Mon Jan 23, 2012 7:24 pm
				by loudsubz
				Posted: Mon Jan 23, 2012 7:26 pm
				by loudsubz
