Page 1 of 2
				My First Cabinet Build (pics)
				Posted: Sun Jan 30, 2011 3:34 am
				by KTOKTO
				Hey.
In the process of building my first cabinet ever. One of two omnitop 15's we will be using as the PA tops in my band along with a tuba.
Here are some pictures after a long day one. (I got too excited at how damned well everything fit together, then got kind of manic and couldn't stop.)
Going to replace the multipurpose screws with something more presentawble and hope to have everything wired and fired up tomorrow.
Have a buddy doing a fine job on the wiring...
				Re: My First Cabinet Build (pics)
				Posted: Sun Jan 30, 2011 6:46 am
				by wounded horse
				she's a beauty.
				Posted: Sun Jan 30, 2011 8:32 am
				by LelandCrooks
				Very nice.   What's the aluminum edging?
				Posted: Sun Jan 30, 2011 9:12 am
				by KTOKTO
				LelandCrooks wrote:Very nice.   What's the aluminum edging?
It's a piece of 1/2" angled aluminum about 1/16" thick. Picked it up from the hardware store by their sheet metal, metal rods etc.
I cut it to length, sanded it with 80 grit paper with an electric hand sander and rattle can clear coated it. It kind of looks like it has been machine turned.
				Posted: Sun Jan 30, 2011 9:37 am
				by David Sample
				Very sweet, great job!
				Posted: Sun Jan 30, 2011 1:39 pm
				by Mikey
				Huh??? You did that in ONE DAY???
Looks SWEET!
				Posted: Sun Jan 30, 2011 2:17 pm
				by DJPhatman
				I like the look, and some fine workmanship there KTOKTO! Congratulations on you first of many builds!
Just a question. Why didn't you go for the melded array?
				Posted: Mon Jan 31, 2011 9:24 am
				by KTOKTO
				Mikey wrote:Huh??? You did that in ONE DAY???
Well, kind of.
 I cut the wood and glued the structure togther Friday past midnight and let the adhesive set up until Sat. All in all it took a good couple days.
				Posted: Mon Jan 31, 2011 9:27 am
				by KTOKTO
This was just try 1. I have the tweerters for the melded array but I just wanted to get something up and running quick this weekend.
I have some powder coated grill material from PE in the mail and am planning on adding the melded array next weekend.
				Posted: Mon Jan 31, 2011 9:39 am
				by KTOKTO
				A couple more photos
				Posted: Mon Jan 31, 2011 11:40 am
				You need squared edge corners to match the aluminum. Penn-Elcom makes them.
				Posted: Mon Jan 31, 2011 2:00 pm
				by KTOKTO
				Bill Fitzmaurice wrote:You need squared edge corners to match the aluminum. Penn-Elcom makes them.
I totally agree. I was shopping around last night for something that would work better on a flat edge. Thanks for the lead! I will post the finished pics when I get those on.
Thanks.
				Posted: Mon Jan 31, 2011 3:33 pm
				KTOKTO wrote:Hey.
Reality check: Power and driver excursion demands go up as frequency goes down. The total size of the subs should be twice that of the tops, minimum.
				Posted: Mon Jan 31, 2011 3:50 pm
				by KTOKTO
				Bill Fitzmaurice wrote:KTOKTO wrote:Hey.
Thanks for the info. Rookie question here... by "size", do you mean the surface are of the drivers?
Thanks!
				Posted: Mon Jan 31, 2011 3:56 pm
The cabinet. With two OTop 15s you need
at least two T48s to have a balanced system. By the same token if two T48s are more subs than you need then two OTop 15s are more tops than you need.
