SLA Pro
Locked
SLA Pro
#1 Post by Bill Fitzmaurice »
Here's the SLA Pro, loaded with four Alpha 6 woofers and six 1016 tweeters, compared to the OTop 12:
Obviously the SLA doesn't compete with the OTop; that's what you get when you make small size the #1 priority. However, compared to commercial line array offerings the SLA very much holds it's own. Here it's compared to the Peavey VersArray 12:
And here it's compared to the Bose Panaray MA12:
BTW, if you're thinking about an MA12, you must use it with the dedicated $500 Bose controller for EQ correction. The SLA Pro has flat enough response that it will work very well with no EQ.
Locked
