Limiter set up in DRPA+
schadstr
#1 Post by schadstr »
just purchase a DRPA+ would like to know how do i set up the limiter in DRPA+ for t24's
BTW i have minimal to no knowledge on limiter/compressor ect : :oops:
2 T24's
4 sl36
4 jbl eons
2 QSC K12
2 Crown macroteck 2400
1 crown xls900
1 drpa+ just added
denon 3700
denonmixer
serato sl
bbe sonic maximizer
Re: Limiter set up in DRPA+
#2 Post by Tom Smit »
Oh no! Did they not ship the manual? :shock: :lol: hint hint
schadstr
#3 Post by schadstr »
no sorry tom just stupid :horse: like that :noob:
2 T24's
4 sl36
4 jbl eons
2 QSC K12
1 crown xls900
1 drpa+ just added
denon 3700
denonmixer
serato sl
bbe sonic maximizer
#4 Post by Tom Smit »
Just so that you might be able to get "un-stoopid", here's a link to the official DBX forum. http://www.dbxpro.com/forum/viewtopic.php?f=61&t=959 Quite a bit of reading, I know, and probably can get a bit confusing too. But slowly and surely wins the race. I can't directly answer your question because I have never operated, or even seen a DRPA+.
Edit to add the link :wall:
SeisTres
#5 Post by SeisTres »
Just know it has a compressor and a limiter, so when setting it, just make sure it is the limiter. Then it has "overeasy" which is used mostly for tops for the compression to be less noticeable. However, for the subs you want to none of that. Just plug in your amp at the setting you will have it and then measure the voltage (no speaker). You will need a voltage meter.If you do no have one and just want the amp not to clip, then you can do that instead.
schadstr
#6 Post by schadstr »
great thanks seistres ill try tonight :clap:
2 T24's
4 sl36
4 jbl eons
2 QSC K12
1 crown xls900
1 drpa+ just added
denon 3700
denonmixer
serato sl
bbe sonic maximizer
