When is a corner too far to use?
Posted: Wed Oct 27, 2010 1:37 pm
I may be in a really big room in December, likely centered on a long wall. Any specifics on when is a corner too far to use for loading?
Donny
Donny
Loudspeaker Design
https://billfitzmaurice.info/forum/
Where is the dance floor? If it is also centered on the long wall, then wall load the subs and be done with it.doncolga wrote:I may be in a really big room in December, likely centered on a long wall.
you did had a mean looking stack there.... =)SeisTres wrote:My friends wedding was somewhat like this as the corners were a little far and the dance floor was right smack in the middle of the room. What I did was just placed the subs up against the wall at 1/3 from the other wall (so 2/3 from the opposite wall). Bass was even through out the whole room without any really noticeable nulls or hotspots (and stupid annoying for the table right next to them which I designated as "the band table").
It ended up being just for looks as ended up using single jacks on each pole and three titans with only my xls402 driving everything. And even like that, being near the subs was extremely annoying once things got pumping, and the volume at the dance floor was VERY good.BoostFab wrote:you did had a mean looking stack there.... =)SeisTres wrote:My friends wedding was somewhat like this as the corners were a little far and the dance floor was right smack in the middle of the room. What I did was just placed the subs up against the wall at 1/3 from the other wall (so 2/3 from the opposite wall). Bass was even through out the whole room without any really noticeable nulls or hotspots (and stupid annoying for the table right next to them which I designated as "the band table").
wall loading did fill the room with bass nicely.
