QSC PL2 218 amp
Posted: Sun Sep 19, 2010 3:42 pm
by reactive
im trying to power 4 dr280 per side with this amp (2) loaded with a 3012 and 22 pieso array
also im looking at a PL2 236 for 8 t48 loaded with the 3015lf
thanks before hand ! :hyper:
Re: QSC PL2 218 amp
Posted: Sun Sep 19, 2010 3:57 pm
reactive wrote:im trying to power 4 dr280 per side with this amp (2) loaded with a 3012 and 22 pieso array
The 218 will give you 225 watts per cabinet at 8ohms per cab, running four per side. The 3012 can take more wattage, but with 4 per side, you should have plenty of volume. However, you are driving both sides of the amp at 2 ohms....might be pushing it a little too hard - especially since the 280s can take more than this amp has to give - you might run it into clipping and overheat it.
The 236 is enough to run the subs at full recommended voltage....but again - at war volume you are pushing both sides pretty hard at 2 ohms.....
If you keep this whole rig at 1/2 volume, there shouldn't be problem ....but, I'd double my amps and let them run 4 ohms a side if you plan to take the paint off the walls.
Re: QSC PL2 218 amp
Posted: Sun Sep 19, 2010 4:03 pm
by reactive
i would be running 2 pl 218 , plus 2 pl236 for the subs , so doble the amps to rip the paint of the walls?
Re: QSC PL2 218 amp
Posted: Sun Sep 19, 2010 4:09 pm
reactive wrote:i would be running 2 pl 218 , plus 2 pl236 for the subs , so doble the amps to rip the paint of the walls?
Plenty for the subs - be sure and limit them.
Tops will get 300 each at 1%THD or 260 each at 0.5%THD.....should remove the paint and the primer....and maybe shake some drywall screws loose.
And no clipping or overheating.
Re: QSC PL2 218 amp
Posted: Sun Sep 19, 2010 4:13 pm
by reactive
thanks bruce for the info
