Page 1 of 2
A question about black duratex...
Posted: Thu Sep 16, 2010 9:03 pm
by la malta
Hey... you guys might find this a little funny or vane, BUT...
Black Duratex isn't really all that black is it? I only saw it in person once and it was dj tecthreat's omnitops. But from what I remember of that and all the pictures its more like a super dark green or grey.
I know its kind of silly but I want BLACK. Like SUPER black. BLACK as you can get. Anyone know what my options are?
I used that truck bed stuff from wallmart once for a small vented 12". The colors what I want but I never gigged with this thing or anything and it doesn't seem like you guys recommend it much.
Re: A question about black duratex...
Posted: Thu Sep 16, 2010 9:06 pm
by WB
Black Duratex is black. At least the several pails I have are.
Posted: Thu Sep 16, 2010 9:13 pm
by David Carter
It's lighter before it dries. Then it gets darker. Then, as gets scuffed and worn over time, it lightens up a bit. But it should be pretty darn black when it a fully-cured fresh coat.
Posted: Thu Sep 16, 2010 9:15 pm
WB wrote:Black Duratex is black. At least the several pails I have are.
+1
mine is Black with kind of a Black tint.....somwhere between Black and Black would best describe it.
Posted: Thu Sep 16, 2010 9:25 pm
by netwerks
It's black.
Posted: Thu Sep 16, 2010 9:32 pm
by la malta
Guys, as I look through every black duratexed speaker in the reviews section, the black handles, corners (plastic and metal), dish plates, grills etc. are noticeably darker and contrast with the paint. I might be crazy for thinking its green but I don't think I'm crazy for thinking its a lighter color. Maybe they are not fully cured fresh coats but I still think I'm looking for something else and just want to know what other things people have tried.
Posted: Thu Sep 16, 2010 9:43 pm
by netwerks
I think the only way you will get "blacker" is black oil base paint.
Posted: Thu Sep 16, 2010 9:45 pm
by la malta
I put a couple PA handles and corners and stuff up against my sub I was talking about. Seemed like they were a better color match than the pics.
Posted: Thu Sep 16, 2010 9:53 pm
Black DuraTex is black. If the hardware in the pics looks different it's because of the different reflective properties of the hardware.
Posted: Thu Sep 16, 2010 10:05 pm
by netwerks
Bill Fitzmaurice wrote:Black DuraTex is black. If the hardware in the pics looks different it's because of the different reflective properties of the hardware.
+1
Posted: Thu Sep 16, 2010 10:54 pm
by Doug Hart
Bill Fitzmaurice wrote:If the hardware in the pics looks different it's because of the different reflective properties of the hardware.
+1
Bill beat me to it.
It's black, and it doesn't get any blacker than black.
Posted: Fri Sep 17, 2010 12:19 am
by la malta
Fair enough. I'm gonna order a small can and see if I like it.
Posted: Fri Sep 17, 2010 5:45 am
by David Carter
I may be wrong, but I think the difference between the Duratex and the hardware, rather than being a difference in color, is a difference in finish. Think of paint from the hardware store. You get a different look from a flat vs. satin vs. eggshell vs. high gloss finish even if they are the same color paint.
Posted: Fri Sep 17, 2010 11:04 am
by LelandCrooks
Definitely has a greenish tint when wet, especially the spray grade. It's black when cured.
Posted: Fri Sep 17, 2010 11:07 am
by bzb
Unless there's a female trolling here, we're all men. It's black. There is no "shade" of black.
Although the next time I need help picking out curtains, I know who to ask.
:D
This is with one coat of Duratex on top of flat black Sherwin-Williams acrylic primer. The access panel has no Duratex on it, only the primer. You can make out the wood grain below the primer.
Untitled by bzbatl, on Flickr
