Ampeg svt speaker/BP102
Vuja de
#1 Post by Vuja de »
Question: Supposedly a direct replacement according to Ampeg is that a BP102 is recommended. Does anyone know if they are that close in specs?
The reason I ask is because I have an SVT 210 cabinet not being used and I was thinking that the drivers could be pulled and used for either a T39 or even a WH10?
Thanks for any responses in advance.
Re: Ampeg svt speaker/BP102
The SVT driver is 32 ohms. The direct replacement is the Legend B810. I have no clue what might be in the SVT210. But I seriously doubt it's the BP102. More likely it's akin to an Alpha or Beta 10.
Vuja de
#3 Post by Vuja de »
Bill Fitzmaurice wrote:The SVT driver is 32 ohms. The direct replacement is the Legend B810. I have no clue what might be in the SVT210. But I seriously doubt it's the BP102. More likely it's akin to an Alpha or Beta 10.
Actually the number on the magnet states that it is 4 ohm.
The number is 86-510-4
This is a quote I got off of Talkbass forum:
"Hi Adam,
The closest we offer to that would be the Legend BP102-4:
http://www.eminence.com/guitar_speaker_ ... B_CAT_ID=5
Regards,
Anthony Lucas
Sr. Lab Technician
Eminence Speaker LLC"
I heard that if you email Eminence with the number stamped on the speaker they will give you the T/S specs.
I will try this and get back.
Thanks
Vuja de
#4 Post by Vuja de »
Wow talk about a quick response!!!
Wasn't even 15 minutes before Anthony got back to me.
Well here they are. Unfortunately no graph so it probably doesn't help with the rising midrange response.
Specs look pretty close to the Beta10
Hi Todd,
Here are the T/S parameters for 10401:
05-RE OHMS 3.34
06-LE MH .74
07-QM 7.01
08-QE .510
09-QT .470
10-XMAX MM 4.60
11-BL TM 7.47
12-EFF % 1.43
13-FS HZ 48.38
14-MMS GMS 27.99
15-CMS mm/N .3867
16-RMS NS/M 1.2139
17-VAS LTRS 66.58
18-SD SCM 350.12
19-EBP 95.0
20-SPL dB 93.5
Regards,
Anthony Lucas | Customer Service
P.O. Box 360
838 Mulberry Pike
Eminence, KY 40019
Phone: 502.845.5622 Ext. 341
Fax: 502.845.5653
#5 Post by Bill Fitzmaurice »
"Hi Adam,
Only because it's 4 ohms. It would probably work better in a top than a sub.
Vuja de
#6 Post by Vuja de »
Hey Bill, how about a WH10?
I've Been looking for a reason to build some.
#7 Post by Bill Fitzmaurice »
Vuja de wrote:Hey Bill, how about a WH10?
Without an SPL chart it's a crapshoot. Whatever you do all must use the same driver for the same response.
Vuja de
#8 Post by Vuja de »
Thanks for the responses Bill. I guess since I have the drivers and have been wanting to build WH10's, why not try it and see what happens. Worst case is they don't work out but at least I have the cabinets built with everything else ready to go minus drivers.
