Goldwood 1016 Piezo response
Posted: Fri Aug 20, 2010 7:59 am
by bubblersound
Purple (5) 1016 in straight array
Green (5) piezos on wooden horn
Re: Goldwood 1016 Piezo response
Posted: Fri Aug 20, 2010 10:53 am
by bgavin
I can't tell which is which.
Posted: Fri Aug 20, 2010 10:57 am
by guitarkeys.com
If my eye are correct, I believe the straight array has the bump at 8.5k.
Jamie
Posted: Fri Aug 20, 2010 10:58 am
by WB
guitarkeys.com wrote:If my eye are correct, I believe the straight array has the bump at 8.5k.
Jamie
My eye tells me the same.
Posted: Fri Aug 20, 2010 11:19 am
by bgavin
I can't tell the colors at all.
Mic calibration file is not used.
Unknown input voltage and measurement distance.
OP, please add some more info.
Posted: Fri Aug 20, 2010 11:21 am
by bubblersound
guitarkeys.com wrote:the straight array has the bump at 8.5k.
Jamie
correct
Posted: Fri Aug 20, 2010 3:54 pm
That response above 10kHz is way low, so something is off with your measurement protocols.
Posted: Fri Aug 20, 2010 6:11 pm
by bubblersound
It's a Shure vocal mic (sm or pg 58), not calibrated. I measured a Eminence Delta Pro 8a in a small enclosure and it looks much like Eminence posted, all the way up to 5k. Although, the mic response posted by Shure is far from flat, especially above 2khz.
Anyway, I did the test because I was skeptical of the tweeters actually playing down to 2khz. They do! The wooden horn is to try to get the elements closer. They are 1 7/8" center-to-center and seem to couple better.
By ear, I feel the homemade horn sounds better and a little less harsh with some eq.
Posted: Fri Aug 20, 2010 6:31 pm
by Sydney
Incorrect choice of mic for measurement - far from flat - it has a presence peak
Syd
