Don Keele's Keynote Speech on CBT Line Arrays
Posted: Mon Aug 02, 2010 1:29 am
The CBT theory was applied to loudspeaker arrays by Keele in 2000 (Keele CBT Paper 1) where he extended the concept to arrays based on circular-arc line arrays and toroidal-shaped curved surface arrays. Keele also extended the concept to straight-line and flat-panel CBT arrays with the use of signal delays (Keele CBT Paper 2). The 3D sound-field of CBT circular-arc line arrays was analyzed by Keele in 2000 (Keele CBT Paper 3) . In 2003 Keele also described the practical implementation of CBT circular-arc line arrays (Keele CBT Paper4). In 2005, he described a design variation of the CBT loudspeaker line array, called a ground-plane CBT array, which is intended to operate very close to a planar reflecting surface. This is part 5 of the 6 part keynote speech.
I believe Wi can be sighted in the audience in later parts. Six parts overall, check the descriptions
