New OT212's
- Paul Norman
New OT212's
I have 2 new OT212's with 2512's and NSD 2005's that I used for the first time this weekend. They are great!
Fri nite for an 80's band outdoors we used 4 T48's centered, 2 OT112's and 1 OT212 on each side ( on top). It was very clean and very loud! I use a DBX Driverack PA and turned the mains down 2db and the subs up 2 db on the Xover to get a good balance. Sat. nite at the same venue for a 50's 60's band I used 4 T48's and 1 OT212 on each side and the balance was even. They were more then enough. These OT212's are awesome! As a side note when I use the OT212's with the OT112's I have the 212's run from the right stereo out on the console for power shading and EQ'd with their own EQ. Their eq is a little different the 112's. Great design! Thanks Bill.
