PL Premium equivalent for Italy?
GekoMusic94
#1 Post by GekoMusic94 »
I can't find a equivalent of the PL premium here in italy...
Please help me...
Have:
2x FBT Jolly8ra (active)speakers (100-20.000Hz)
1x Voice System SUB VS8 (active)subwoofer (55-100Hz)
1x MTH-30 (RCF LF12G301)
Zack Brock
Re: PL Premium equivalent for Italy?
#2 Post by Zack Brock »
If you can't find it and the shipping isn't too prohibitive, Leland @ speakerhardware.com sells it and may be able to ship it to you internationally.
I'm not able to offer an alternative suggestion, sorry. PL Premium is really good glue.
Zack Brock
#3 Post by AntonZ »
Most affordable I have found in Europe so far: Soudal 60A. Can be hard to find, over here it is available from Hornbach DIY stores. More expensive glues are widely available from Bison and Pattex: Bison PU construction adhesive and Pattex PU construct.
(all are available in 310ml tubes)
bzb
#4 Post by bzb »
You really need to stick with flexible polyurethane adhesive. Might want to look at a few brands and post up specs if you can find them.
Did ya'll notice Mike Holmes (Holmes on Homes on HGTV) is always plugging PL Premium?
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
#5 Post by DJPhatman »
What you are looking for is "expanding polyurethane adhesive". It does not need to be flexible after curing. "Gorilla Glue" is another brand name. Look for an adhesive that will fill gaps as wide as 8mm and cures air-tight.
bzb
#6 Post by bzb »
Oops - good catch Phat. I meant expanding, and typed flexible :wall:
Bobby Shively
mpm32
#7 Post by mpm32 »
Too bad you're not closer to Rome, I'm going to be there in a couple of weeks. I could've stuffed a bunch of tubes in my luggage. Although I don't know if I would get through security. lol
https://www.facebook.com/CharlieDontSurfCT/
2-DR250
2-Wedgehorn 8
2-16" T39
#8 Post by AntonZ »
mpm32 wrote:Too bad you're not closer to Rome, I'm going to be there in a couple of weeks. I could've stuffed a bunch of tubes in my luggage. Although I don't know if I would get through security. lol
:lol:
I have thought about a similar situation when I completed wiring my first melded array: try to get through customs on the average airport with that :noob: :bash:
lazyman
#9 Post by lazyman »
Omnitop 12 (Kappa12 - melded piezo) - 2
Titan39 (B&C 12BG100) - 1
https://www.facebook.com/djserviskula?fref=ts
