Car audio system
Posted: Fri Apr 09, 2010 2:53 pm
Hey y'all.
Despite the fact that I'm currently deep in the build process of 4 DR200's and probably 2 (or 4) T60's, I'm starting a car audio install. At least in my head.
I'd like any advice on configuration as I value the opinions of people on this forum over just about anywhere else!!
So obviously there will be an autotuba or two. This is a given.
I'm thinking a 3-way active system using this (http://www.minidsp.com/index.php) as the dsp. If anyone knows of something better, simpler, etc please mention it.
The vehicle is a ford econoline 150, which will have a new Alpine or Pioneer deck (not chosen yet (can I get away with 2 Volt pre-outs, or should I play the extra $80 or so to get he 4- 5 volt?). Deck power to start, but I'll install my amp later on (4 channel).
I was going to just go with a component set, but I won't be happy if I can't tweak everything (like phase and TA), so I decided DSP is a necessity.
My questions are mostly about the midbass and tweeter options.
First of all, are "car audio drivers" necessary, or can I use 8 Ohm home or pro audio driver's that meet the requirements? I've heard car audio drivers are tougher - is this BS?
The aforementioned requirements being audiophile sound (or close), relatively inexpensive (no more than $250 for mid's and tweets), and the midbass driver should match up well with an autotuba and sound good in a (relatively small) sealed kickpod (do ported kickpods even exist?).
I'd like to go with silk dome tweeters.
I've heard good things about, Seas W18's, CDT's gold woofer's, Peerless SLS's, Eminence Alphalite 6A's, Tang Band W6...
I'm inclined to go with Tang Band just because Bill choose those as the upgraded option for the autotuba's. I've also had good experience with Vifa drivers at home.
Please advise with specific tweeter and woofer recommendations if possible!!
Cheers,
Conrad.
Cheers,
Conrad.
