This amp is giving me fits.
Posted: Tue Mar 30, 2010 8:59 pm
I recently acquired a Crown 460CSL on Craigslist for around $125.00.
This thing is really... odd.
Here's how my rig used to be:
Bass pre-amp (Presonus Studio Channel) -> line mixer ->amp
I had it wired so that the mixer presented a dual-mono signal to the amp and ran each Jack-10 to its own channel. At a couple of indoor gigs it was just ludicrously over-powered. No problem, I'd rather have too little power than too much.
I wanted to simplify things so I pulled the mixer and threw everything into a 4-space rack (it was originally in an 8-space). I omitted the mixer and a couple of other non-essential boxes and ran the output of the pre-amp straight into the line-1 input on the Crown.
Last Saturday I had an outdoor gig. Totally free-field. No walls, no ceiling, so I was prepared to have to push the rig a lot harder to get a usable amount of power out of it. To my dismay it was completely anemic. Per the diagram on the back I plugged the banana jacks across the red terminals and then ran a jumper between the cabs. I checked for polarity and they were properly in phase. It was so bad I had to pretty much stay off the E-string to keep from clipping the amp. Cone travel didn't seem excessive so I really doubt that it was cone slap I was hearing. I ended up switching basses in the second set to an active with a lot more midrange and totally dialed the 100-hz out of the mix at my preamp.
Yesterday I was looking at the owner's manual and this thing is really strange.
Here's the full manual:
http://www.crownaudio.com/pdf/legacy/125168.pdf
This is the excerpt that is confusing me. It's on page 11:
Stereo mode (both channels driven):
240 watts into 4 ohms.
200 watts into 8 ohms.
Bridge-Mono mode:
455 watts into 8 ohms.
395 watts into 16 ohms.
Parallel-Mono mode:
455 watts into 2 ohms.
400 watts into 4 ohms.
Wait... This amp can only go down to 8 ohms bridged? Ok, I guess it is 13 years old. But wait... Parallel Mono? In that mode it'll go down to 2 Ohms. What the hell? If you look at the diagram on page 7, you have to run a jumper between the red posts and then connect your plugs to the channel 1 output.
If I understand this correctly... and I don't doubt that I'm not... parallel mono is pretty much the same as bridging minus the phase inversion between channels, right? Why the strict impedance requirements when bridging?
So, here are my questions:
Were the problems I was having due to being free-field? I was expecting 6db or so of loss from a lack of boundary loading, should I have expected 9 or more?
The rated 455 watts is perplexing. They don't indicate what that means... Does Crown rate by max, RMS, program or something else? Assuming that the 6 or so ohm load of a pair of 2512 jacks would pull the full power out of this amp, is this approaching the max power of the Jacks, did I perhaps damage something early on?
Is there something else I'm not thinking of? Unfortunately, this amp has one light for power. It has no other means to communicate with me. I also did not have my trusty Fluke so I couldn't measure A/C voltage or anything. The first set was pure misery. It's hard to give a good performance when you're pissed at your rig and having to mentally re-write every bass line and sing at the same time.
Sorry for the super-long over-detailed post. Anyone have thoughts or suggestions?
Bridge-Mono mode:
Parallel-Mono mode:
