Tuba 60
Locked
Tuba 60
#1 Post by Bill Fitzmaurice »
Tuba 60 1x15 and T48 1x15, 36 inches wide:
T60 has the advantage below 32Hz, T48 the advantage above 32Hz. If you don't really need the output below 32Hz that T60 is capable of you don't need the T60, so be well sure of it before you make your choice.
Tuba 60 15" and 20" wide, loaded with a LAB 12 driver:
Tuba 60 27" wide, loaded with a LAB 15 driver:
Tuba 60 30 inches wide loaded with two Lab 12 drivers. A pair of 15 inch wide 1x12s will have the same response.
Tuba 60 20" wide loaded with one LAB 12 compared to the JBL 728, measured 1m half-space responses both with 2.83v input:
Tuba 60 30" wide loaded with two LAB 12 compared to the 2x21 loaded EAW SB2001, both with 2.0v input:
T60 and Lab Sub, both loaded with two Lab 12 drivers.
Locked
