T-39's ready to go to work!
DJDAVE
#1 Post by DJDAVE »
Seems like it took forever to get these done (which they're still not, cosmetically), but I really did go about this very casually. I do have the tilt back handles on, but haven't cut out the fabric yet. Adding the curved front was an after thought. I made these square per the plans, and added the extended sides, top and bottoms afterwards which took a lot longer than I thought it would. The grills are as cheap as you can get... Lowes expanded metal 1 sheet is 27 x 96 for under $10.00 (per Bill) and did both subs which are 23" wide and using the 3012lf. Although this isn't the most rigid metal, I think I'm going to reinforce it with another sheet behind it.
Currently, I'm using felt behind the grill (really cheap) and I don't believe this should cause any problems in the sound, but I can always easily change this out for speaker cloth.
Like I had mentioned in a previous backyard review, these sound incredible and I had so much more room to turn these up. These will definitely compete with the big names out there.
I really can't wait to crank up these bad boys!!!
Thanks again Bill.
Scott Brochu
Re: T-39's ready to go to work!
#2 Post by Scott Brochu »
The fronts are sexy. :clap:
What kind of cloth and did it come in black or did you paint the cloth along with grills?
Drumming is a way of life.
ME LIKE TO HIT THINGS!
DJDAVE
#3 Post by DJDAVE »
Thank Scott. I just used standard black felt found at any fabric store or Walmart, but I haven't tested them with the felt on them yet. I painted the grills first, dabbed the back with a sponge and glue, then layed the felt on. I did practice with some scraps first and found that a very fine coating of spray paint on top of the finished grill will give it and even deeper, richer glossy black, but I haven't done it to these yet.
#4 Post by Bill Fitzmaurice »
DJDAVE wrote:Thank Scott. I just used standard black felt found at any fabric store or Walmart, but I haven't tested them with the felt on them yet. .
Felt might offer too much resistance to use it on a grille.
Zack Brock
#5 Post by Zack Brock »
Those are dang sexy!
Can you post a close up picture of this steel mesh + felt grille you made?
Zack Brock
SeisTres
#6 Post by SeisTres »
:clap:
VERY nice!
LOL, mine wouldn't even have "deck and patio" paint on them if it wasn't because the wood doesn't do go against the weather.
Spoon
#7 Post by Spoon »
Those look GREAT DJDAVE! If the felt doesn't work out try using black pet screen (from Lowes) behind your steel mesh.
2 OT12's 2512 CD
2 OT12's 2512 Melded Array
4 Titan 39's 30" 3012LF
4 Titan 39's 20" 3012LF
6 Wedgehorn 8's
1 Wedgehorn10
2 AutoTuba's 18" w/MCM 8"
https://www.facebook.com/pages/LSW-Lana ... 080?ref=hl
DJDAVE
#8 Post by DJDAVE »
I'm hoping to maybe get these out soon to do an A-B comparison of one with the grill on, and one with it off to see how much of a difference there will be, if any. I do think Bills right that there may be too much resistance using felt. I can see it now, the grills pulsating in and out with the beat of the music and then just tearing off the speaker all together.
Thats a great idea also. I'm thinking plan-B will be in full gear very soon.
Scott Brochu
#9 Post by Scott Brochu »
DJDAVE wrote:Thank Scott. I just used standard black felt found at any fabric store or Walmart, but I haven't tested them with the felt on them yet. I painted the grills first, dabbed the back with a sponge and glue, then layed the felt on. I did practice with some scraps first and found that a very fine coating of spray paint on top of the finished grill will give it and even deeper, richer glossy black, but I haven't done it to these yet.
Thanks for the up close photo.
Does the paint on the grill feel like it would flake off after a few uses? Or do you think it is going to hold up to road ware.
DJDAVE
#10 Post by DJDAVE »
To be honest, I think the grills would get damaged before the paint would scrape off, especially for bands moving equipiment in and out of clubs and bars all the time. As a dj moving my own stuff, I tend to be a little more careful, but with a couple of extra coats of rustoleum, you'll should be fine, but it will not flake off.
I just want to mention this again, that the grill really isn't that rigid and I will probably be reinforcing it in back just for precautionary measures (I do have a brace right above the mouth), but even with my craziest parties, no one has ever even touched my subs, so I'm not too worried.
