Per the Peavey PV-2600 manual:
"DDT™ ACTIVE LEDS
These indicators illuminate when DDT compression is taking place in the associated channel. With
the DDT ENABLE / DEFEAT switch on the back panel in the ENABLE position, these LEDs indicate
clipping is occurring in the corresponding channel."
"DDT™ (DISTORTION DETECTION TECHNIQUE) SWITCH
This switch is used to enable or defeat the DDT compressor circuitry. It is also a conventional pushpush
type, requiring a small “tool” to activate. The IN position is DEFEAT; the OUT position is
ENABLE. Normally, the DDT function should be enabled to minimize the possibility of either or both
channels going into clipping or overload. With this feature defeated, a severe overload could cause
the mains circuit breaker to trip."
"Peavey’s patented DDT (Distortion Detection Technique) compression circuit enables the sound
technician to maximize the performance of the amplifier/speaker combination by preventing the power
amplifier from running out of headroom (clipping). This compression system is activated by a unique
circuit that senses signal conditions that might overload the amplifier and activates compression
(reduces the channel gain) when clipping is imminent. The threshold of compression is clipping itself,
and no specific threshold control is used. This technique effectively utilizes every precious watt
available for the power amplifier to reproduce the signal, while at the same time minimizing clipping
and distortion. DDT significantly reduces the potential of loudspeaker degradation and damage, and is
the most effective, automatic, hands-off approach to the problem of power amplifier clipping.
Since PV series power amplifiers use a circuit breaker for overcurrent protection, the DDT
compression system plays an even more important role in continuous performance by preventing
each channel from clipping and overload. Continuous operation at clipping can cause the circuit
breaker to trip, but with the DDT activated, this problem is minimized. For this reason, the DDT
compression system should always be enabled."
Have you tried defeating this feature to see if the lights go out? Are you indeed getting 60V across the subs when they're hooked up? What is the wall power doing during this whole charade? Just brainstorming....
