New Behringer EPQ304 for TLAH/SLA's
Posted: Sat Jan 16, 2010 2:51 am
by gilscales
I am gathering parts/info for an HT build and just seen these new amps at NAMM, I am thinking that 2 of these 4 channel units putting out 75w into 4 ohms per channel, 2 ea for bi-amping the front and 2 remaining for the rear surrounds
Question; if I bi-amp the front 3 channels (TLAH/SLA) do I still need the same x-overs or do I use something else like a high pass and low pass filter? what is best?
Re: New Behringer EPQ304 for TLAH/SLA's
Posted: Sat Jan 16, 2010 2:57 am
by Radian
No. The same crossovers wouldn't be used. Bi-amping requires the signal to be crossed over actively ahead of the amps. There are a lot of options regarding equipment that will do this either in the analog or digital domain.
Posted: Sat Jan 16, 2010 9:33 am
gilscales wrote:I am gathering parts/info for an HT build and just seen these new amps at NAMM, I am thinking that 2 of these 4 channel units putting out 75w into 4 ohms per channel, 2 ea for bi-amping the front and 2 remaining for the rear surrounds
Considering the low prices on full featured 5.1 and 7.1 receivers that eliminate the need for anything other than a plate amp for the subs I don't see this as useful. Bi-amping TLAH/SLA has no benefit IMO.
