BFD Pro DSP1124P or the FBQ 2496
Posted: Tue Jan 05, 2010 3:41 am
by gilscales
Does anyone use one of these to tame room modes on there subs in a HT set up? if so how good are they? and which one to use?
Re: BFD Pro DSP1124P or the FBQ 2496
Posted: Tue Jan 05, 2010 12:01 pm
by gdougherty
Attack it with Bass traps and sub placement first, then look at what you might want to do with EQ. Room modes are often untamable with EQ because they're phase interactions between reflections in a room. From what I've seen, a properly treated room will eliminate most need for EQ.
Posted: Tue Jan 05, 2010 12:55 pm
by gilscales
gdougherty wrote:Attack it with Bass traps and sub placement first, then look at what you might want to do with EQ. Room modes are often untamable with EQ because they're phase interactions between reflections in a room. From what I've seen, a properly treated room will eliminate most need for EQ.
Thanks, will try that first for sure!
