DR200 (x4) Build Thread
SoundInMotionDJ
Re: DR200 (x4) Build Thread
#91 Post by SoundInMotionDJ »
David Carter wrote:Installed the adjustable top hats into the bottom access covers of two of the cabs...
What is the source & part number for the adjustable top hats? Based on your success, I may be in the market to retrofit all my DR's with those...
--Stan Graves
10 T39S + 10 DR200 + 1 T48
David Carter
#92 Post by David Carter »
SoundInMotionDJ wrote:What is the source & part number for the adjustable top hats? Based on your success, I may be in the market to retrofit all my DR's with those...
Source = Leland
Make you read my post about the testing I did on the tripod stand. It works great with one cab per stand. Two works great if the bottom one is angled downward. I haven't tried it yet, but I anticipate having problems with two per stand if the bottom one is facing straight out.
Dave
- 2 x Titan 39 (BP102 - 14"W)
DaveK
#93 Post by DaveK »
The solution to your top-hat dilemma is to get two fixed hats from Leland and mount them in the other two cabs at the balance point. Then you put those on the bottom when stacking straight.
David Carter
#94 Post by David Carter »
DaveK wrote:The solution to your top-hat dilemma is to get two fixed hats from Leland and mount them in the other two cabs at the balance point. Then you put those on the bottom when stacking straight.
Wow! That's a great idea! I don't know why I never thought of that. :roll:
I probably won't get to it right away, but I'll definitely do that! Thanks! :clap:
Dave
David Carter
#95 Post by David Carter »
One last picture just to show the four DR200's alongside the rest of the BFM family. They're kind of tucked away in a corner right now with other junk piled up on the T39's and DR250, so it's not the best shot, but here they are...
Dave
Scott Brochu
#96 Post by Scott Brochu »
WOW! nice stack. :clap:
Now take your break and get back to work :loler:
I do not see an wedges. :mrgreen:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
David Carter
#97 Post by David Carter »
Scott Brochu wrote:I do not see an wedges. :mrgreen:
They're next on the build list... someday. I'm also anxious to get a new mixer one of these days, and I really need to start saving my pennies for the Dingwall bass that's on my GAS list. :wink:
Dave
Chris Betancourt
#98 Post by Chris Betancourt »
Let me know I'll bring the drum set out so we can jam :hyper: the stack looks really good!!!! WOW. :P
Christopher Betancourt
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
Gauss
#99 Post by Gauss »
David Carter wrote:After some sanding, grinding, and even a little trimming off the ends of some of the arrays, I finally got them to fit well...
I'm working on my piezo arrays, and chose to alternate the angled cuts (like you did) instead of clipping through screw heads. I'm a little worried about installing them now. What exactly did you do to make yours fit in?
BASS: Combo Amp & Titan39
David Carter
#100 Post by David Carter »
Have you tried fitting them in and had problems, or are you just worried because you read that I had problems? If you haven't tried it yet, you may not have any trouble. I had to do some tweaking on three of the four, but the fourth fit with no problem due to small variations in the splay angle of the cabs.
What I ended up doing was trimming a tiny bit off the end of the finished arrays with the table saw at a 3 or 4 degree angle so that the top and bottom of the array matched the angle of the top and bottom panels of the cab. It's hard to explain, but if you can confirm that you're having trouble with your arrays being too tall, I'll try to draw a picture to help me explain it better.
Dave
Gauss
#101 Post by Gauss »
You're right, it's pre-emptive. I held two together that had the lugs facing out and couldn't see how they would fit, since the lugs were about as wide as the edge of the piezo. I'll have to wait and see when I get the array glued up.
David Carter
#102 Post by David Carter »
Gauss wrote:You're right, it's pre-emptive. I held two together that had the lugs facing out and couldn't see how they would fit, since the lugs were about as wide as the edge of the piezo. I'll have to wait and see when I get the array glued up.
There are two different issues here. One is whether or not the backs of the arrays are too wide to fit into the space between the supports. The other is whether the arrays are too tall to fit between the top and bottom panels. My problem was the overall height of the arrays. What I did to prevent the width from being an issue was to rotate the elements where the lugs were facing out. Take a look at the pic below to see what I mean...
Dave
particleman14
#103 Post by particleman14 »
yea , I had the same problems with the melded array and I ended up alternating the piezos screw slots 2-1-2-1 like you did. I found it worked quite nice and only had to grind down 2 of the screw slots to make everything fit. definitely try to make a perfect melded array jig as mine was off ever so slightly, but luckily staggering the screw slots saved me lots of time and a reorder of piezos..
sadfsadf
spongebob1981
#104 Post by spongebob1981 »
David Carter wrote:(...)
Now THATS what I'd call a fridge-like rig. G R A T Z! Big time! :fruit:
"Yep, deep orange" 2xJ10
(other site) 50W DIY Tube Head
"La música es el delirio. Bienvenidos al delirio."
Drey Chennells
#105 Post by Drey Chennells »
Very nice work and documentation. Respect.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
