Re: 1st BFM build: 2 X Omni 15 TallBoy in 2-12 configuration
Posted: Wed Nov 20, 2013 11:08 am
Thanks 88h88! Your encouragement means a lot, no fooling. As I keep saying, a good community has assembled around Bill's work.
Of course Bill's plans, and his cutting jig too, get much of the credit. Nevertheless the builder has at least to try to cut things to the proper size, at the correct angle, and so on. Learned much about how to do that during this build thus far.
My wife and daughter have made clear that they are not interested in hearing this cabinet work at ordinary operating levels
so I have not yet had a chance to crank it. The most powerful amp I've got at the moment is 60 watts RMS at 8Ω if memory serves, so won't be able really to crank it anyway, but will be able to run it much louder than in the bedroom (45 watts RMS at 8Ω max there), where the cab has run at maybe 15 watts max, for perhaps 30 seconds.
This cab is I guess nominally 4Ω, so perhaps there will be a few more watts available. If all goes well, I will drag the box outside tonight and run a few tests using AudioTool, then report the results here. This will not be the half-space test yet, have to go up to the front field for that, but should get more accurate results than in a bedroom.
Best
--aeolos
Best
--aeolos
