Curved Grill WH10
N.Webber
Re: Curved Grill WH10
#91 Post by N.Webber »
Final assembly…
Wiring the Piezo arrays:
Piezo array and wiring in place:
Stuffing installed:
Deltalite 2510 installed:
Last look inside the horn:
Driver's leads attached to X-Over:
Grill foam cleared at the screws locations:
Front grill and back access cover attached, assembly complete:
…and tucked inside the covers:
I only did a basic check to confirm all is working – first impression: they do sound clear and true :D
On Monday I have a school concert in which I will be using the WH10s, we'll 'see how they sound'.
Later this week I'll have time for further checking and twinkling with the x-over if necessary.
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
http://www.boniton.co.il
Harley
#92 Post by Harley »
Stunning!
ripNdeb
#93 Post by ripNdeb »
Harley wrote:Stunning!
This!
Dave Non-Zero
#94 Post by Dave Non-Zero »
+lots.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
kynetx
#95 Post by kynetx »
Your craftsmanship is stunning.
I wish I were patient enough for my work to flow like this, but once it takes on a recognizable shape I can't help but rush...
My wife is getting irritated with me saying "wow" and "damn!" every couple of minutes.
jswingchun
#96 Post by jswingchun »
Plus one to all of the above comments. This has been a fun thread to watch.
:clap:
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
N.Webber
#97 Post by N.Webber »
Thanks for the compliments… :oops:
The 'road test' at the beginning of the week was OK, though not too demanding re. levels and quality so not really true test.
This morning I arranged a test set-up. Measurement mic. placed like this:
Here shown the 'natural' response of the WH10 elements (Bypassing the internal passive crossover filters):
When connected through the X-over, I noticed two problematic points:
First, the HF/Piezos section was too dominant so it was attenuated by about 3dB (as suggested in the plan).
Secondly, the 2kHz hump in the woofer's response was still prominent despite the roll off of the filter at 1.5kHz, so I modified the roll off point to 1kHz.
This smoothed the hump considerably.
Here are the response plots of the complete WH10:
Some notes: Don’t be bothered by the seemingly rough trace. This is because of the high resolution (1/24 octave) that was left on purpose.
Although less smooth and appealing then say 1/3 octave, it is the true response picture and shows the offending points more clearly.
The SPL levels are not absolute but only relative within each plot. Offsetting the plots was done only for viewing purpose.
The top two traces are direct feed (PC/sound card -> amp -> WH10) with no EQ
The bottom trace is with EQ correction applied (LS9-16 rack EQ inserted on output mix):
Here a shot of the EQ corrections on the LS9:
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
cave
#98 Post by cave »
Amazing build
Built 2 x DR 250
Building 8 DR 250
Built 8 x OTOP 12 JARRAY
Built 2 TITAN 48
escapemcp
#99 Post by escapemcp »
A 3 year resurrection!! If any thread is going to be bumped though, I'm glad it's this one :)
