Titan 39 20" Wide 12" Sub Build (Completed)
Re: Titan 39 20" Wide 12" Sub Build (Primer Question)
#91 Post by DJPhatman »
RENDOG wrote:I read a pretty long thread about which primer to use and really didn't get a good answer from it.
I'm going to use Duratex and would like to know what to use as primer.
Primer is not necessary with DuraTex. Once the PL has fully cured (about 7 days) You can cut the excess away with a sharp chisel.
RENDOG wrote:Also, what sandpaper do I use (grit)?
40-60 grit is perfect. Gives the DuraTex something to "bite" into.
My suggestion: Dilute your 1st coat of DuraTex 3:1 (IOW 3/4 cup Duratex to 1/4 cup water. Distilled water is best, no contaminants. Mix well and apply as base coat only. Works with spraying or rolling.
RENDOG
#92 Post by RENDOG »
Thanks Phat and Tom.
Here are some recent pics.
Hurricane nuts.
Final Bondo application
ewetho
Re: Titan 39 20" Wide 12" Sub Build (Final Steps)
#93 Post by ewetho »
Ah the good 'Ol Titan. Memory flash back of building 4 T8s. Nice. Make sure to do leak check thoroughly and ENJOY!!!
Spoon
#94 Post by Spoon »
Nice job! Where'd you get that foot long allen wrench? LOL
2 OT12's 2512 CD
2 OT12's 2512 Melded Array
4 Titan 39's 30" 3012LF
4 Titan 39's 20" 3012LF
6 Wedgehorn 8's
1 Wedgehorn10
2 AutoTuba's 18" w/MCM 8"
https://www.facebook.com/pages/LSW-Lana ... 080?ref=hl
RENDOG
#95 Post by RENDOG »
Spoon wrote:Nice job! Where'd you get that foot long allen wrench? LOL
LOL....it does look like it's longer than the access panel.
jswingchun
#96 Post by jswingchun »
Be careful with those chipped out areas around the t-nuts on your access hole. They could make it difficult to get an air-tight seal.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
bzb
#97 Post by bzb »
jswingchun wrote:Be careful with those chipped out areas around the t-nuts on your access hole. They could make it difficult to get an air-tight seal.
Looks like he's got it covered between the epoxy holding the t-nut in (should be airtight at the base/flange) and the weatherstripping is on the inside of the nuts.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
RENDOG
#98 Post by RENDOG »
The access panel is airtight as far as I can see and hear.
It's silent and I did the air hose test and found no leaks. One time, i didn't tighten a couple of bolts tight enough and I immediately heard air coming out. Once those were tightened, it was silent again.
I'm definitely building another one but i'm still on the fence about which table saw to purchase.
I've had recommendations for somewhat highend ones ($500) but i've also been told that a cheaper one ($200) with a strong fence will be fine considering I used only a circular saw with this first Titan.
My issues were not with the long first cuts (39" sides etc..) because I used a homemade jig
http://www.youtube.com/watch?v=CH5dW-Qc ... r_embedded#!
My problem was the angle cuts and how long some really simple cuts took me.
Any recommendations or advice? Anyone have a $200 table saw that performs pretty well?
#99 Post by Bill Fitzmaurice »
I have a $100 saw. And a $200 fence.
RENDOG
#100 Post by RENDOG »
Thanks Bill. Leland messaged me and recommended a bisenmeyer fence. Which one are you using?
#101 Post by Bill Fitzmaurice »
http://www.mulecab.com/
RENDOG
#102 Post by RENDOG »
Thanks.
#103 Post by LelandCrooks »
Nice. I'd never seen that one. May have to reequip the antique delta.
RENDOG
#104 Post by RENDOG »
Weather conditions were favorable for applying Duratex, so I did. I followed the advice I found on the forums, Leland's instructions, Bill's instructions and I also called Duratex afer my first coat.
The Duratex is pretty cool. It looked great even after just one coat but really started looking nice during the second coat.
I am noticing it's a bit "flaky" in certain areas.
Harley
Re: Titan 39 20" Wide 12" Sub Build (Applied Duratex)
#105 Post by Harley »
Nice work :clap:
