Page 6 of 8
Re: Slim THTLP
Posted: Sat Feb 26, 2022 4:01 am
by JensToft91
Trust me. When I struggled to carry it in to the living room, I got that look that only women can do. I think only men who build extremely unnecessary things will experience it.
And - this is probably twice the size of what I think is appropriate. But I just need to know what it sounds like.
Like all other build threads, this also does out a bit. Sorry!
Now it's time to finish it :hyper:
Re: Slim THTLP
Posted: Sat Feb 26, 2022 8:58 am
by JensToft91
Well. We can call this "The isn't". Because it's not straight in any direction :noob:
Re: Slim THTLP
Posted: Sat Feb 26, 2022 10:26 am
by Rich4349
How do you plan on using it: laying down or standing up? Or no set plan? If you think it will get used in one orientation most of the time you could carefully belt sand down a bit of the floor facing side at an angle, removing enough of the material to make it lay flat. If there's more to remove than you think is safe, you could glue a strip of 1/4" or 3/8" to the lower half of that side to bring the low portion up, leaving less high side to remove.
Re: Slim THTLP
Posted: Sat Feb 26, 2022 10:33 am
by JensToft91
Laid down behind the couch. I'll put it on rubber feet, I think.
I got this idea. Clamp the rug I used as protection for the floor, and then color it with what ever fabric I'd like.
But that cheap rug ended up looking pretty damn smooth.
I don't know how I'll finish the buttom, yet - but I'll probably figure it out.
I'm simply amazed about how this turned out. A 10 minute job.
Re: Slim THTLP
Posted: Sat Feb 26, 2022 10:43 am
by Rich4349
Resourceful! You can just run a carpet knife or exacto blade around the inside, an inch or two from the end for a clean border.
Re: Slim THTLP
Posted: Sat Feb 26, 2022 11:55 am
by AntonZ
JensToft91 wrote: Sat Feb 26, 2022 10:33 amI don't know how I'll finish the buttom, yet - but I'll probably figure it out.
How about: not. As long as it is not rocking or vibrating to the floor, and the floor is consistently dry, you should be perfectly fine with no finish whatsoever. No one is going to sneak behind the couch, flip the thing over and then start moaning like "Hey now listen here Jens, how come this side is not as pretty as the others".
Yep, looks perfectly fine by me. That is, assuming you don't have any cats in the house.
Re: Slim THTLP
Posted: Sat Feb 26, 2022 12:28 pm
by JensToft91
I mean where the driver lid goes. But but I already figured it out. I'll make another lid, with the same fabric, and screw on top of the other one.
The first one will look just like the side facing the floor.
I'd like too someone just "flip it" 😁
Re: Slim THTLP
Posted: Sat Feb 26, 2022 10:08 pm
JensToft91, nice recovery on the finish! :clap:
Re: Slim THTLP
Posted: Wed Mar 23, 2022 4:42 am
by JensToft91
Finally! The driver is en route!
Re: Slim THTLP
Posted: Wed Mar 23, 2022 11:47 am
by DaveMacKay
JensToft91 wrote: Wed Mar 23, 2022 4:42 am Finally! The driver is en route!
I'm looking forward to hearing how you feel it sounds.
Re: Slim THTLP
Posted: Wed Mar 23, 2022 11:53 am
by shawn_g
The wait for the driver would kill me :shock: :)
Re: Slim THTLP
Posted: Sat Mar 26, 2022 1:50 pm
by JensToft91
Driver has arrived, looks awesome.
Quick question while it breaks in, and i finish the rear chamber:
Why does the voltage change over time, during break-in? I set a tone at 25 Hz, 10 volts exactly. After to hours, it measured 13 volts. Turned it down to 10.
Now after 10 hours, it measured 13 again.
Is this because I use a cheap digital board amp, or is it because the driver specs are changing under break-in, and change the impedance of the driver at 25 Hz, while the resonant frequency drops?
If it's amp related, I have a great reason to buy a new one.
Re: Slim THTLP
Posted: Sat Mar 26, 2022 2:04 pm
It shouldn't change, so it's the amp or the sine wave generator. While impedance will shift as the driver breaks in that will cause the current to vary, not the voltage.
Re: Slim THTLP
Posted: Sat Mar 26, 2022 2:17 pm
by JensToft91
Guess it deserves a dedicated amp then 🙄 haven't changed the signal at all. Thank you for the quick answer.
Re: Slim THTLP
Posted: Tue Mar 29, 2022 1:47 pm
by JensToft91
I'm happy to report that 20 Hz horn extension has been achieved! And way, way, way cleaner than the PC12-NSD.
I won't make a review until I've dialed it in - as I know I'm having amplifier - issues.
Playing a -3db 20 Hz sine wave - with audyssey EQ enabled(boosts the low end), the signal clips at -23db on the marantz. The amplifier is only putting out 6 volts at this stage, and I'm able to turn the knob on the board-amplifier all the way to 16 volts before the amp is giving in.
It the solution to lower the subwoofer-out on the receiver as much as possible, and then turn up the sub-amp to compensate?
This is known as a gain issue in the pro-world, right?
