Last night I was hoping to get the side on. As the cab is not totally square
, I was hoping to use the sides to pull it into alignment. This meant that I wanted to use the 30 minute PL - mainly for strength, but it would also allow me time to get the alignment right. The plan was to apply the PL, then stand on top of the cab (as that lines it all up) and then debut the new brad nailer to hold everything in place whilst the gloo sets. I did notice a warp in the centre of the panel, so first job was to clamp that out:
Then I grabbed the PL, only to discover that the plastic had broken along the line between the top of the tube and the 'nipple' that you screw the application tube to. As a fix, I have attempted to epoxy the hole. To give it even more strength, I then epoxied the application tube onto the previous layer of epoxy on the hole:
I'm hoping that this will hold, although I reckon it's only 50/50 whether it will. I wanted to let the epoxy set hard, so I gave up on the idea of fitting on the side last night, and moved onto the tweeter array.
First I marked up the holes on the underside:
Then I drilled them...:
...all the way through:
This now gave me something to aim at. To further aid me, I inserted a screw into the hole on the sheath side, and cut a bit of pipe to the rough angle:
This then allowed me to mark up where the hole in the sheath should go:
I could then measure the extremeties of the hole from the trailing edge of the module and then mark up the whole module. The 2 lines in the previous pics are the result of this.
Then it was onto actually cutting the hole. I discovered what I thought was the perfect dremel attachment for this:
So with my 'dentists drill' attachment...:
...I proceeded to 'sand' the hole bigger:
Whilst this worked reasonably well to start, it soon started making burning marks. The sawdust was adhering to the sanding stone and making it smooth, and trying to sand with a smooth object just ain't gonna work (unless you are trying to start a fire)! This was the result on the first hole though:
I needed another plan, and having made the first hole allowed me to test a few things. I realized that I could use the drill to go straight through the sheath (perpendicular):
Once through, I could then start rotating the drill upwards, and that would create my channel for the PVC pipe:
In order to make sure I was on target, I used the hole through the tweeter array back as a guide for the brad point of the drill bit. It's kind of hard to see the hole in this picture, but it's there:
Once the brad of the drill was rotating in that hole and the drill was vertical, I knew that the required hole had been made. There was a tiny bit of splintering on a couple of the holes, but I cannot imagine that you wouldn't get some splintering even on a drill press. For the other side, I may clamp a scrap bit of bendy ply over the top of the hole, and that should eliminate the splintering
So after making 5 holes, it was time to break out the glue gun. It was hard getting to some parts of the tubes 'inside' the array, so I just gooped it on and let it run down the tubes. They are now totally encased in hot-melt, and not going anywhere
The 'neat' side looked much better though:
A quick demonstration of how tight the screw/PVC pipe combo is:
There is no glue in the way of that screw, I took the screwdriver to it, and then it just fell down the hole. I was thinking of inserting a couple of pins just into the sides of the pipe. The screws could then never come loose when removing the array. This could work out to be a lifesaver if any work ever needs to be done 'in the field'.
OMG... just accidentally hit the power button of my PC and it shut down.
Upon reboot Firefox restored my session and unexpectedly, saved all of this post!
I wasn't looking forward to typing all this in again!! Thanks FF (& try doing that with IE
Back in the garage it was getting late, so powertools were a no-no. I was going to sand the PVC flat, but instead I used an exacto-knife to cut off the extra pipe and glue. I used it at full length and bent it against the sheaths to get the cutline flush to the outside. This left a perfect looking hole/pipe combo:
If I
had taken the sander to it, it would have probably caused the glue to re-melt (does hot glue do that?) and end up all over the sandpaper. The exacto knife was the perfect tool for the job in this case. As Bob Ross said "We don't make mistakes, we just have happy little accidents".
Tonight I will complete the tweeter array holes, and hopefully get at least one of the sides on. Then tomorrow it'll be the other side and soldering up the tweeter array, and then, FINALLY, I can fire these up and hear what all the fuss is about!
Thank god it's the weekend, so I can play with it all I want (and at the volume I want
