Bruce, that's how I did my T24s as well. Cheap flat latex black paint. Works great and looks great. I might not have enough Duratex though. I might be making an order here soon. I still have to do the access panel hole for the binding posts too. I'm going to counter sink it in a bit, so it's flush.Bruce Weldy wrote:Just use some cheap flat black paint. A gallon should be 15 bucks at HD. It dries so fast that you can start putting on a second coat by the time you get through with the first. Then go have lunch and start the duratex. Same thing, start the second coat when you finish the first. You can have all the paint done in a day.
I've done it this way on every build I've done.
New THT Build!
Re: New THT Build!
Re: New THT Build!
If you are short of Duratex, put on an extra coat or two of flat black, then go sparingly with the duratex - you might be surprised how good it will look....and it aint' gonna' be getting moved around a lot, right?
Re: New THT Build!
Really nice work. Can't wait to hear what you think.
1299s L/C/R | Volt8s | Crown amps | 24" THT x 4| Minidsp 10x10 2x4HD | Panamax 5300PM | LG 65B6 | Oppo 203 | Crowsons | HoverBoss | Behringer NX amps
THT Build
THT Build
Re: New THT Build!
OK, another shot with the access panel fitted:
Everything was ready, so I started applying the paint. Looking good. First a light coat. Second coat should do nicely, then a single coat of duratex. Looking pretty good.
Flat Black Latex:
Flat Black Latex:
Re: New THT Build!
After being busy all weekend, I got some time tonight to do some more flat black painting. All sides have 2 coats except one. The mouth is 1/2 done. My plan is to finish the black latex in the garage, then move it to the basement for the duracoat. I know it's obsessive, painting the inside of the access panel flanges, but I like how it looks. Here is what it looks like now...
Painted up nice...
Cover is ready for duratex.
Painted up nice...
Re: New THT Build!
It won't take a lot of duratex to finish that off. A really good primer base like that makes it so much easier to cover and uses a whole lot less of the expensive stuff.
I cringe every time someone says they are putting duratex directly on the wood....that stuff is way too expensive to have it soaking into the wood.
Good looking primer coat!
Re: New THT Build!
Since it's for inside I'd be leaning toward some regular black satin or semi-gloss paint.
Re: New THT Build!
I'm going to do a light coat of duratex. It will be in the back corner and will be used as a jungle gym for my son, I think. So the duratex will work nicely.
Re: New THT Build!
Great job, btw. I'm might be building one this winter or T45. Can't decide.
